"Enable Efficient MultiCast Forwarding (IPMG Snooping)" on AX routers
xanman
Hi
Does anyone know how to "Enable Efficient MultiCast Forwarding (IPMG Snooping)" on RT-AX86U routers?
I have seen the function un wireless / Professional, but I Would like it to be under LAN / IPTV, just like in the AC routers ?
By selecting the version you want when you enable it on the LAN, perhaps?
No,
Tried all the settings. The picture attached is my old AC66U Router, which had the IPMG Snooping, and my IPTV always worked perfectly.
Did you reboot after changing settings each time? I don't know if that is necessary, but I always include it when I test to ensure it does survive a reboot too.
Ive rebooted my STB, My Router. after every setting change. No luck
I have a ticket open with Asus, but that is not going anywhere.
What firmware are you using? After flashing the firmware, you want on it, did you ever reset it fully before putting it in use?
RT-AX86U_386.1_beta2, and yes, I have factory reset it after, and tried my IPTV after. and no luck.
Hopefully, Beta 3 or later resolves these issues for you.
