Enabled Guest WIFI is gone after reboot
chinese_ys
I went through manual but did not find the answer. I have latest merlin firmware on my N66U and I enabled/configured a Guest WIFI. It was running and I can connect to it with pre-defined password. However I found it is gone/disabled after the router rebooted. I could click the corresponding Enable button to have my Guest WIFI settings brought back though.
So is this by design OR I should click a specific button to save the configuration?
Thanks,
/S
No one??
Here is further on what I found: it seems like the guest WIFI will stay enabled for the length of time I configured (4-Hour) and then auto-disabled.
So this is what should be by design...
Try setting it to limitless, that's what mines on and it stays after reboot. I assume it's because you have it set to 4hours, but I'm only guessing.
Would the parental control work over the guest network to restrict time ?
I don't know.
I don't know.
Thanks for the suggestion. I checked parental control page on the latest stable merline firmware, it indeed will restrict certain client time but requires mac address...which wont work for the guest WIFI.:)
RT-AC66U
I have seen same behavior.
My guess is that at reboot date time is not correct and this makes guest network expired.
