Enabling DHCP auth options 60 and 61 on Netgear Voxel Routers for Sky UK etc
a workaround could be done, even if you upgraded the FW (would need a customized Voxel build of course)
1. Configure your Internet Setup with PPPoE, have your Username and Password stored (need to press Apply)
2. Re-configure your Internet Setup as DHCP as it is supposed to be
3. Modify /etc/init.d/net-wan in setup_interface_dhcp() function with following changes
local u_wan_domain=$($CONFIG get wan_domain)
+local dhcp_opt61
+[ "x$($CONFIG get wan_pppoe_passwd)" != "x" ] && dhcp_opt61="-c \"$($CONFIG get wan_pppoe_username)|$($CONFIG get wan_pppoe_passwd)\""
udhcpc -b -i $WAN_IF -h $u_hostname -r $($CONFIG get wan_dhcp_ipaddr) -N $($CONFIG get wan_dhcp_oldip) $dhcp_opt61 ${u_wan_domain:+-d $u_wan_domain} &
else
4. Save the changes and reboot, you should be able to configure/keep this configuration works for your DHCP option 60/61.
If Voxel can consider similar change and make it to his build, then those users could minimize the efforts to make, and keep, it work.
William
I have an add-on for this function.
But I can't test it.
Anyone interested in testing it?
Sorry to revive this old thread, but I will soon replace my R7000 with an R7800 and being with Sky I'd be very interested in understanding which way is the best to set up DHCP 60/61...
Tia.
I have it in my add-on.
Just need someone to test it, before I make a Beta-test-release.
Tia.
Meanwhile I'm trying to follow Voxel's instructions on how to gain SSH access (appendix A of his README file), and can you advise what I'm doing wrong as I'm stuck on point no. 7
Tia.
