Is there a way to install Dieharder on Asuswrt-Merlin ?
@kvic - Thanks for the info...I ran some tests and really didn't see any difference between the 32K and 16K default cache sizes. I also didn't compile with thread support since I saw it was still experimental. I initially chose 2048 for the write watermark (it was the default for rng-tools), and don't see any adverse effects. Just for completeness, here's my result on an AC68P, overclocked to 1.2GHz
Reason this discussion was timely.....dnscrypt added an entropy level 'check' as part of their startup. The router at boot was right on the edge of the value they were checking.
@kvic
I've convinced myself haveged+/dev/random produces very high quality random numbers!
That said, you seems to be well verse in these, if you have MIPS ASUS router, please help me with https://www.snbforums.com/threads/help-test-dnscrypt-installer-binaries-for-ac66u-or-n66u.38835/ , it should help all the MIPS router users want to use dnscrypt-proxy
Do the ARM versions not have a hardware module that can be enabled like on the RaspberryPi and then make use of /dev/hwrng?
$ dieharder -a
# dieharder version 3.31.1 Copyright 2003 Robert G. Brown #
rng_name |rands/second| Seed |
mt19937| 1.88e+07 |2795046327|
test_name |ntup| tsamples |psamples| p-value |Assessment
diehard_birthdays| 0| 100| 100|0.60256659| PASSED
diehard_operm5| 0| 1000000| 100|0.07022370| PASSED
diehard_rank_32x32| 0| 40000| 100|0.17784530| PASSED
diehard_rank_6x8| 0| 100000| 100|0.80585788| PASSED
diehard_bitstream| 0| 2097152| 100|0.41778223| PASSED
diehard_opso| 0| 2097152| 100|0.76204551| PASSED
diehard_oqso| 0| 2097152| 100|0.35015079| PASSED
diehard_dna| 0| 2097152| 100|0.12788252| PASSED
diehard_count_1s_str| 0| 256000| 100|0.54505096| PASSED
diehard_count_1s_byt| 0| 256000| 100|0.96779942| PASSED
diehard_parking_lot| 0| 12000| 100|0.48712953| PASSED
diehard_2dsphere| 2| 8000| 100|0.58931846| PASSED
diehard_3dsphere| 3| 4000| 100|0.09927068| PASSED
diehard_squeeze| 0| 100000| 100|0.75046600| PASSED
diehard_sums| 0| 100| 100|0.44773303| PASSED
diehard_runs| 0| 100000| 100|0.10338501| PASSED
diehard_runs| 0| 100000| 100|0.97011787| PASSED
diehard_craps| 0| 200000| 100|0.61118756| PASSED
diehard_craps| 0| 200000| 100|0.69956421| PASSED
marsaglia_tsang_gcd| 0| 10000000| 100|0.26501783| PASSED
marsaglia_tsang_gcd| 0| 10000000| 100|0.57053545| PASSED
sts_monobit| 1| 100000| 100|0.97881936| PASSED
sts_runs| 2| 100000| 100|0.10399735| PASSED
sts_serial| 1| 100000| 100|0.53407611| PASSED
sts_serial| 2| 100000| 100|0.03805457| PASSED
sts_serial| 3| 100000| 100|0.03956705| PASSED
sts_serial| 3| 100000| 100|0.58571599| PASSED
sts_serial| 4| 100000| 100|0.56874174| PASSED
sts_serial| 4| 100000| 100|0.04393908| PASSED
sts_serial| 5| 100000| 100|0.70348996| PASSED
sts_serial| 5| 100000| 100|0.66169741| PASSED
sts_serial| 6| 100000| 100|0.22543221| PASSED
sts_serial| 6| 100000| 100|0.38395047| PASSED
sts_serial| 7| 100000| 100|0.91441323| PASSED
sts_serial| 7| 100000| 100|0.98937095| PASSED
sts_serial| 8| 100000| 100|0.99866793| WEAK
sts_serial| 8| 100000| 100|0.63893892| PASSED
sts_serial| 9| 100000| 100|0.63550490| PASSED
sts_serial| 9| 100000| 100|0.15116107| PASSED
sts_serial| 10| 100000| 100|0.57306004| PASSED
sts_serial| 10| 100000| 100|0.80585672| PASSED
sts_serial| 11| 100000| 100|0.67899745| PASSED
sts_serial| 11| 100000| 100|0.30536095| PASSED
sts_serial| 12| 100000| 100|0.41719706| PASSED
sts_serial| 12| 100000| 100|0.64721637| PASSED
sts_serial| 13| 100000| 100|0.73677136| PASSED
sts_serial| 13| 100000| 100|0.52156829| PASSED
sts_serial| 14| 100000| 100|0.68926048| PASSED
sts_serial| 14| 100000| 100|0.48586001| PASSED
sts_serial| 15| 100000| 100|0.96613461| PASSED
sts_serial| 15| 100000| 100|0.53939427| PASSED
sts_serial| 16| 100000| 100|0.63923745| PASSED
sts_serial| 16| 100000| 100|0.69735016| PASSED
rgb_bitdist| 1| 100000| 100|0.22321355| PASSED
rgb_bitdist| 2| 100000| 100|0.16814724| PASSED
rgb_bitdist| 3| 100000| 100|0.96148147| PASSED
rgb_bitdist| 4| 100000| 100|0.88697956| PASSED
rgb_bitdist| 5| 100000| 100|0.83313688| PASSED
rgb_bitdist| 6| 100000| 100|0.60561643| PASSED
rgb_bitdist| 7| 100000| 100|0.10540463| PASSED
rgb_bitdist| 8| 100000| 100|0.62222124| PASSED
rgb_bitdist| 9| 100000| 100|0.18260905| PASSED
rgb_bitdist| 10| 100000| 100|0.69386474| PASSED
rgb_bitdist| 11| 100000| 100|0.39507452| PASSED
rgb_bitdist| 12| 100000| 100|0.99478030| PASSED
rgb_minimum_distance| 2| 10000| 1000|0.52450131| PASSED
rgb_minimum_distance| 3| 10000| 1000|0.74764716| PASSED
rgb_minimum_distance| 4| 10000| 1000|0.63473060| PASSED
rgb_minimum_distance| 5| 10000| 1000|0.04077417| PASSED
rgb_permutations| 2| 100000| 100|0.17369396| PASSED
rgb_permutations| 3| 100000| 100|0.99120092| PASSED
rgb_permutations| 4| 100000| 100|0.91403463| PASSED
rgb_permutations| 5| 100000| 100|0.65840808| PASSED
rgb_lagged_sum| 0| 1000000| 100|0.43611859| PASSED
rgb_lagged_sum| 1| 1000000| 100|0.28297405| PASSED
rgb_lagged_sum| 2| 1000000| 100|0.49760278| PASSED
rgb_lagged_sum| 3| 1000000| 100|0.99625221| WEAK
rgb_lagged_sum| 4| 1000000| 100|0.22210189| PASSED
rgb_lagged_sum| 5| 1000000| 100|0.57665684| PASSED
rgb_lagged_sum| 6| 1000000| 100|0.01702124| PASSED
rgb_lagged_sum| 7| 1000000| 100|0.06738001| PASSED
rgb_lagged_sum| 8| 1000000| 100|0.86508353| PASSED
rgb_lagged_sum| 9| 1000000| 100|0.29070416| PASSED
rgb_lagged_sum| 10| 1000000| 100|0.84167097| PASSED
rgb_lagged_sum| 11| 1000000| 100|0.36918453| PASSED
rgb_lagged_sum| 12| 1000000| 100|0.89480078| PASSED
rgb_lagged_sum| 13| 1000000| 100|0.46134528| PASSED
rgb_lagged_sum| 14| 1000000| 100|0.61863658| PASSED
rgb_lagged_sum| 15| 1000000| 100|0.31866855| PASSED
rgb_lagged_sum| 16| 1000000| 100|0.80726860| PASSED
rgb_lagged_sum| 17| 1000000| 100|0.43705489| PASSED
rgb_lagged_sum| 18| 1000000| 100|0.47957687| PASSED
rgb_lagged_sum| 19| 1000000| 100|0.18729481| PASSED
rgb_lagged_sum| 20| 1000000| 100|0.46135472| PASSED
rgb_lagged_sum| 21| 1000000| 100|0.09089204| PASSED
rgb_lagged_sum| 22| 1000000| 100|0.67811978| PASSED
rgb_lagged_sum| 23| 1000000| 100|0.97705094| PASSED
rgb_lagged_sum| 24| 1000000| 100|0.35150224| PASSED
rgb_lagged_sum| 25| 1000000| 100|0.23028791| PASSED
rgb_lagged_sum| 26| 1000000| 100|0.31077537| PASSED
rgb_lagged_sum| 27| 1000000| 100|0.67050746| PASSED
rgb_lagged_sum| 28| 1000000| 100|0.80429034| PASSED
rgb_lagged_sum| 29| 1000000| 100|0.32071299| PASSED
rgb_lagged_sum| 30| 1000000| 100|0.66122709| PASSED
rgb_lagged_sum| 31| 1000000| 100|0.40904539| PASSED
rgb_lagged_sum| 32| 1000000| 100|0.96775948| PASSED
rgb_kstest_test| 0| 10000| 1000|0.40989789| PASSED
dab_bytedistrib| 0| 51200000| 1|0.29099220| PASSED
dab_dct| 256| 50000| 1|0.05487172| PASSED
Preparing to run test 207. ntuple = 0
dab_filltree| 32| 15000000| 1|0.49559879| PASSED
dab_filltree| 32| 15000000| 1|0.87654489| PASSED
Preparing to run test 208. ntuple = 0
dab_filltree2| 0| 5000000| 1|0.89832193| PASSED
dab_filltree2| 1| 5000000| 1|0.62012949| PASSED
Preparing to run test 209. ntuple = 0
dab_monobit2| 12| 65000000| 1|0.86755948| PASSED
The Linux UDEV rules for this TruRNG device says it is "CDC-ACM device". So when you plug it in, look for /dev/ttyACM0. The Asus router may report that you're plugging in a USB modem. However, it will probably work just fine... except maybe slower than built-in RNG hardware due to the USB stack overhead.Well I bought this http://ubld.it/truerng_v3 and it's shipping to me at the moment.
Yeah, I'm looking forward to play around with thisThe Linux UDEV rules for this TruRNG device says it is "CDC-ACM device". So when you plug it in, look for /dev/ttyACM0. The Asus router may report that you're plugging in a USB modem. However, it will probably work just fine... except maybe slower than built-in RNG hardware due to the USB stack overhead.
2.2 Initialization
Operating system startup includes a sequence of routine actions. This sequence includes the initialization of the LRNG
with constant operating system parameters and with the time-of-day, and additional disk operations and system events
which affect the LRNG using the interface for adding external entropy (discussed in Section 2.5). This sequence of
operations might be easily predicted by an adversary, especially in systems which do not have a hard drive. If no
special actions are taken, the LRNG state might include very limited entropy. (For example, the time of day is given as
a count of seconds and of micro-seconds, each represented as a 32-bit value. In reality these values have very limited
entropy as one can find computer uptime within an accuracy of a minute, which leads to a brute-force search of only
60 × 10^2 < 2^26 different options.)
To solve this problem, the LRNG simulates continuity along shutdowns and startups. This is done by saving a random-seed at shutdown and writing it back to the pools at startup. A script that is activated during system startups and shutdowns uses the read and write capabilities of the /dev/urandom interface to perform this operation.
During shutdown the script reads 512 bytes from /dev/urandom and writes them to a file, and during startup these bits are written back to the /dev/urandom device. This device is defined such that writing to it modifies the primary pool and not the urandom pool (as one could expect from its name). The resulting operations applied to the primary pool are pretty much identical to the effect of receiving these 512 bytes as the encoding of system events, and adding them to the primary pool using the usual procedure for adding entropy, which is outlined in Section 2.5. The only difference is that the added bytes do not increment the entropy estimation. The secondary pool and the urandom pool are refreshed by the primary pool, and therefore the script affects all three pools.
Here's a comment from the Linux kernel source that echos what you are suggesting. And I suppose you could use JFFS to persist the entropy bytes.Regularly save the entropy and restore it on startup ? How would you do this ?
* Ensuring unpredictability at system startup
* When any operating system starts up, it will go through a sequence
* of actions that are fairly predictable by an adversary, especially
* if the start-up does not involve interaction with a human operator.
* This reduces the actual number of bits of unpredictability in the
* entropy pool below the value in entropy_count. In order to
* counteract this effect, it helps to carry information in the
* entropy pool across shut-downs and start-ups. To do this, put the
* following lines an appropriate script which is run during the boot
* sequence:
* echo "Initializing random number generator..."
* random_seed=/var/run/random-seed
* # Carry a random seed from start-up to start-up
* # Load and then save the whole entropy pool
* if [ -f $random_seed ]; then
* cat $random_seed >/dev/urandom
* else
* touch $random_seed
* fi
* chmod 600 $random_seed
* dd if=/dev/urandom of=$random_seed count=1 bs=512
* and the following lines in an appropriate script which is run as
* the system is shutdown:
* # Carry a random seed from shut-down to start-up
* # Save the whole entropy pool
* echo "Saving random seed..."
* For example, on most modern systems using the System V init
* scripts, such code fragments would be found in
* /etc/rc.d/init.d/random. On older Linux systems, the correct script
* location might be in /etc/rcb.d/rc.local or /etc/rc.d/rc.0.
* Effectively, these commands cause the contents of the entropy pool
* to be saved at shut-down time and reloaded into the entropy pool at
* start-up. (The 'dd' in the addition to the bootup script is to
* make sure that /etc/random-seed is different for every start-up,
* even if the system crashes without executing rc.0.) Even with
* complete knowledge of the start-up activities, predicting the state
* of the entropy pool requires knowledge of the previous history of
* the system.
#define INPUT_POOL_WORDS 128
Thread starter | Title | Forum | Replies | Date |
T | IPSec VPN server client IP pool | Asuswrt-Merlin | 1 | |
H | DHCP server change Pool Starting Address | Asuswrt-Merlin | 4 |
Welcome To SNBForums
