Poldi2025Asus
Hi guys,
I'm new to the whole Merlin world. So I ran into some problems after updating Entware on different Routers.
Updating on RT-AX88 U Pro was no problem and everything ran smoothly afterwards.
Yet I also run an AC86U remotely. Also the Updates ran seemingly without problems. At home I noticed that the router was disconnected from tailscale and also wireguard wouldn't work. After checking the router files I noticed that my mount was missing.
My question is if anybody ran into the same issue and what a solution could look like. I think it is unlikely that the drive was formatted or something like that. Maybe there is just a problem with the mount so that reboot of the mount script will solve it.
I ask these questions instead of trying it myself cause the router is located pretty far and I want to try as much viable solutions as possible when I'm there.
What are your ideas?
Thank you very much in advance
Poldi
Poldi
