Entware toolchain problem
oldgringo
When I'm trying to compile some application based on entware toolchain, I always end up on this message:
/opt/entware-toolchain/lib/gcc/mipsel-linux-uclibc/4.6.3/../../../../mipsel-linux-uclibc/lib/libc.a(sigprocmask.os): In function `sigprocmask':
sigprocmask.c:(.text+0x0): multiple definition of `sigprocmask'
/opt/entware-toolchain/lib/gcc/mipsel-linux-uclibc/4.6.3/../../../../mipsel-linux-uclibc/lib/libpthread.a(pt-sigprocmask.os):pt-sigprocmask.c:(.text+0x0): first defined here
Is there any quick fix for it?
I found something like
-int sigprocmask(int how, const sigset_t * set, sigset_t * oldset)
+int weak_function sigprocmask(int how, const sigset_t * set, sigset_t * oldset)
but it's beyond my limits. ;)
Thanks for any help.
The most common reasons is:
  • broken definitions in program has to be compiled,
  • prorgam is not compatible with uClibc 0.9.32 and\or gcc 4.6.3 or it features, which is turned off.
I use the same program/setting with oleg's toolchain (from googlecode v5128) without any problem, but it's optimized for gcc 4.6.4. Is there any significant difference which I should be aware of? Any environment or compiler setting?
