_me_myself_and_i_
Please select an option: s
checking syslog-ng daemon ... alive.
checking system for necessary scribe hooks ...
checking S01syslog-ng ... present.
checking service-event ... present.
checking post-mount ... present.
checking unmount ... present.
checking logrotate cron job ... present.
checking directory links ... present.
checking syslog-ng configuration ...
syslog-ng.conf version check ...Error opening plugin module; module='http', error='libssl.so.1.1: wrong ELF class: ELFCLASS32'
in sync. (3.38)
syslog-ng.conf syntax check ... okay!
scribe installed version: v2.4_4 (master)
scribe GitHub version: v2.4_4 (master)
scribe is up to date!
Press [Enter] to continue:
ldd /usr/sbin/openssl
libssl.so.1.1 => /usr/lib/libssl.so.1.1 (0xf75a7000)
libcrypto.so.1.1 => /usr/lib/libcrypto.so.1.1 (0xf736f000)
libdl.so.2 => /lib/libdl.so.2 (0xf735c000)
libpthread.so.0 => /lib/libpthread.so.0 (0xf7333000)
libc.so.6 => /lib/libc.so.6 (0xf71f2000)
/lib/ld-linux.so.3 (0xf7623000)
file /usr/lib/libssl.so.1.1
/usr/lib/libssl.so.1.1: ELF 32-bit LSB shared object, ARM, EABI5 version 1 (SYSV), dynamically linked, stripped
Is this a known bug? I have a RT-AX86U
