Scribe error='libssl.so.1.1: wrong ELF class: ELFCLASS32'
It looks like NUT is also affected. None of the solutions here has solved the issue for nut-upsmon.
Still get the following error: I have uninstalled, re-installed, forced, used hacks in this thread. Still down.
upsmon: error while loading shared libraries: libssl.so.1.1: wrong ELF class: ELFCLASS32
Entware sure did mess this up.
Have you tried @StarkWiz 's hack? I have and my Asterisk installation became again operational.
I will add that after running the version @cmkelley scripted I had repeated dns failures; I had to re-run the unbound setup on both my 86U on 386.10 and my 88U on 388.2b1.
Also, after running the script and rebooting, both routers were largely unresponsive for a good five minutes or so. I could see the main web page. The 88U had all four cores pegged at 100%, and the 86U had both cores pegged at 100%. Something was working out something. I had slow ssh access and htop wasn't reflecting the usage, but when I could go to the Tools page the usage was close to 4 for the 86U for the 15 and 10 minute periods.
Thanks guys for the script. I just noticed snmpd on my AX88U wasn't running since I last updated entware.
Running the script against libopenssl did the trick. For some reason I still had to force reinstall snmpd, but maybe because I started messing with it before I discovered this thread.
For me, this is the solution for the scribe AX88u.
opkg --force-depends remove libcurl
opkg install libcurl
And reinstall scribe :)
Many thanks. This fixed scribe for me :)
This issue injured a lot of tooling - especially the J tooling. :( I just ran into it last night when I went to do my monthly update check on amtm and the other tooling. Ended up with a lot of:
curl: error while loading shared libraries: libssl.so.1.1: wrong ELF class: ELFCLASS32
MD5 hash of scMerlin does not match - hotfix available - v2.4.0
Fortunately, this thread had the solution a few pages back with the basic commands to fix the openssl dependencies
opkg whatdepends libopenssl
followed by force updating those dependencies....
and then the super handy scripts on page 4.
I suspect we should hang onto these - tightly. Have a great day!
I can't get Scribe to update, it just freezes at the download section. I couldn't get AMTM to update at first either but I did the UU update and it forced updated. But still Scribe freezes at the download.
Also just noticed when I exit AMTM I get errors, I have plenty of space on my USB stick, its like a 16GB or 32GB stick.
This could be a full /jffs/ storage. Check the Tools page in the routers WebGUI.
