error on RT-AC87U USB...
morfy
I have a netgear 790s connected via usb to the RT-AC87U, and daily the connection drops and I have to restart it: what does it depend on ???
Aug 23 12:15:43 kernel: usb 2-2: USB disconnect, address 2
Aug 23 12:15:43 kernel: rndis_host 2-2:1.0: eth2: unregister 'rndis_host' usb-0000:00:0b.1-2, RNDIS device
Aug 23 12:15:43 wsdd2[708]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Aug 23 12:15:45 hotplug: remove net eth2.
Aug 23 12:15:45 wan: finish adding multi routes
Aug 23 12:15:45 WAN_Connection: Ethernet link down.
Aug 23 12:15:46 DualWAN: skip single wan wan_led_control - WANRED off
Aug 23 12:15:47 nat: apply redirect rules
Aug 23 12:15:50 kernel: usb 2-2: new high speed USB device using ehci_hcd and address 3
Aug 23 12:15:50 kernel: rndis_host 2-2:1.0: eth2: register 'rndis_host' at usb-0000:00:0b.1-2, RNDIS device, 00:a0:c6:00:00:00
Aug 23 12:15:51 hotplug: add net eth2.
Aug 23 12:15:51 hotplug: set net eth2.
Aug 23 12:15:57 WAN_Connection: Ethernet link up.
Aug 23 12:16:02 wan: finish adding multi routes
Aug 23 12:16:07 wan: finish adding multi routes
Aug 23 12:16:12 wan: finish adding multi routes
Aug 23 12:16:17 wan: finish adding multi routes
Aug 23 12:16:22 wan: finish adding multi routes
Aug 23 12:16:27 wan: finish adding multi routes
Aug 23 12:16:33 wan: finish adding multi routes
Aug 23 12:16:37 wan: finish adding multi routes
Aug 23 12:16:43 wan: finish adding multi routes
Aug 23 12:16:47 wan: finish adding multi routes
Aug 23 12:16:52 wan: finish adding multi routes
Is the NG 790s running the latest firmware available? Have you tried fully resetting it? What firmware are you running on the RT-AC87U? What features/options or scripts do you use or have enabled on the router beyond the defaults?
When was the last time you did a full reset of your network equipment?
The link below may have some suggestions that you may find useful.
pretty much the latest merlin firmware, but did it with those before too. There is no apparent reason, suddenly it gives the error I described above and I have to restart everything hoping it will restart ... Also tried to reset but nothing changes. It must be said that I also connected a USB 3 in front with timemachine and behind the netgear 790s.
