hello all, new to posting here but an avid reader/lurker for the past 6 months
anyway here is a snippet from my log file, all these stop/start/stop/starts look weird, is this normal for ESR9850 ? ..notice they occur at the same time, down to the second. anyway this is on auto-pilot, no particularly special or weird settings or anything:
I got the ESR9850 from NewEgg a little less than 2 months ago. I love this ESR9850 router but it has a little quirk. There are certain websites that will continually sit at "page loading" FOREVER and NEVER load. (Firefox, Chrome, Safari) ..I have tried opendns, my ISP dns, google dns, and dns relay. I have tried updating the firmware and software. I have even tried vpn with a u.s. address and no success on these webpages. I have tried going back to the old Linksys and everything works fine - pages load.
Example would be:
http://us.gizmodo.com/ (I cannot load this site with ESR9850, hangs at "waiting for...")..but pings are good. that's just one example but there are quite a few others. the sites I require daily all work though. just occasionally I run into sites that refuse to load with this router.
on a sidenote the greatest thing about this router is the speed. I can fully use my fiber connection now. I have seen d/l speeds of 103 Mb/s from my ISP (.jp), whereas my Linksys would max out around 27-30 Mb/s. For about 2yrs I thought that was as fast as I could go, thinking this was normal. I love this router.
I'm just wondering if I need a warranty repair/replacement due to DNS issue and my router services are always stopping/starting. this may be normal but wanted to check because the log file looks weird.
ENGENIUS ESR9850
Model Wireless Gigabit Broadband Router
Mode AP Router
Uptime 14 days 7 hours 19 min 3 sec
Current Date/Time 2010/06/26 19:34:59
Battery Status No battery
Hardware version 1.0.0
Serial Number
Kernel version 1.1.2
Application version 1.1.2
Jun 26 18:40:28 [SYSTEM]: NET, Firewall Disabled
Jun 26 18:40:28 [SYSTEM]: NET, start NAT
Jun 26 18:40:28 [SYSTEM]: NET, stop Firewall
Jun 26 18:40:28 [SYSTEM]: NET, stop NAT
Jun 26 18:40:28 [SYSTEM]: SCHEDULE, stop Firewall
Jun 26 18:40:28 [SYSTEM]: SCHEDULE, stop Power Save
Jun 26 18:40:28 [SYSTEM]: NTP, Local time=2010/06/26 18:40:28
Jun 26 18:40:28 [SYSTEM]: NTP, Daylight saving status: Disable
Jun 26 18:40:28 [SYSTEM]: NTP, Time zone = +9.0 Osaka, Sapporo, Tokyo
Jun 26 17:40:25 [SYSTEM]: NET, Firewall Disabled
Jun 26 17:40:25 [SYSTEM]: NET, start NAT
Jun 26 17:40:25 [SYSTEM]: NET, stop Firewall
Jun 26 17:40:25 [SYSTEM]: NET, stop NAT
Jun 26 17:40:25 [SYSTEM]: SCHEDULE, stop Firewall
Jun 26 17:40:25 [SYSTEM]: SCHEDULE, stop Power Save
Jun 26 17:40:25 [SYSTEM]: NTP, Local time=2010/06/26 17:40:25
Jun 26 17:40:25 [SYSTEM]: NTP, Daylight saving status: Disable
Jun 26 17:40:25 [SYSTEM]: NTP, Time zone = +9.0 Osaka, Sapporo, Tokyo
Jun 26 16:40:22 [SYSTEM]: NET, Firewall Disabled
Jun 26 16:40:22 [SYSTEM]: NET, start NAT
Jun 26 16:40:22 [SYSTEM]: NET, stop Firewall
Jun 26 16:40:22 [SYSTEM]: NET, stop NAT
Jun 26 16:40:22 [SYSTEM]: SCHEDULE, stop Firewall
Jun 26 16:40:22 [SYSTEM]: SCHEDULE, stop Power Save
Jun 26 16:40:22 [SYSTEM]: NTP, Local time=2010/06/26 16:40:22
Jun 26 16:40:22 [SYSTEM]: NTP, Daylight saving status: Disable
Jun 26 16:40:22 [SYSTEM]: NTP, Time zone = +9.0 Osaka, Sapporo, Tokyo
Jun 26 16:40:14 [SYSTEM]: NET, Firewall Disabled
Jun 26 16:40:14 [SYSTEM]: NET, start NAT
Jun 26 16:40:14 [SYSTEM]: NET, stop Firewall
Jun 26 16:40:14 [SYSTEM]: NET, stop NAT
Jun 26 16:40:14 [SYSTEM]: SCHEDULE, stop Firewall
Jun 26 16:40:14 [SYSTEM]: SCHEDULE, stop Power Save
Jun 26 16:40:14 [SYSTEM]: NTP, Local time=2010/06/26 16:40:14
Jun 26 16:40:14 [SYSTEM]: NTP, Daylight saving status: Disable
Jun 26 16:40:14 [SYSTEM]: NTP, Time zone = +9.0 Osaka, Sapporo, Tokyo
Jun 26 16:40:04 [SYSTEM]: WLAN, start LLTD
Jun 26 16:40:03 [SYSTEM]: WLAN, LLTD Stopping
Jun 26 16:40:02 [SYSTEM]: NET, Firewall Disabled
Jun 26 16:40:02 [SYSTEM]: NET, start NAT
Jun 26 16:40:02 [SYSTEM]: NET, stop Firewall
Jun 26 16:40:02 [SYSTEM]: NET, stop NAT
Jun 26 16:40:02 [SYSTEM]: NTP, start NTP Client
Jun 26 16:40:02 [SYSTEM]: DHCP, start DHCP Server
Jun 26 16:40:02 [SYSTEM]: DHCP, DHCP Server Stoping
Jun 26 16:40:02 [SYSTEM]: LAN, IP address=192.168.1.254
Jun 26 16:40:02 [SYSTEM]: LAN, start
Jun 26 16:40:02 [SYSTEM]: LAN, Stopping
Example would be:
ENGENIUS ESR9850
Mode AP Router
Serial Number
