Ext. HDD does not go into hibernation at all times. fw.384.5
Annihilator
ASUS RT-AC66U_B1 rev. B2. External HDD (USB 3.0) does not go into hibernation at all times.
Before that, I had a simple RT-AC66U (not B1) at 380.70. Always went into sleep mode without problems. The same external hard drive was connected.
Config:
USB Setting
Enable HDD Hibernation: YES
Time Period: 180 seconds (Default : 300)
May 20 23:30:35 sd-idle-2.6[13588]: spinning up /dev/sda after 1 mins 1 secs
May 20 23:33:35 sd-idle-2.6[13588]: spinning down /dev/sda after 3 mins
May 20 23:36:05 sd-idle-2.6[13588]: spinning up /dev/sda after 2 mins 30 secs
May 20 23:39:05 sd-idle-2.6[13588]: spinning down /dev/sda after 3 mins
May 20 23:41:05 sd-idle-2.6[13588]: spinning up /dev/sda after 2 mins
May 20 23:44:05 sd-idle-2.6[13588]: spinning down /dev/sda after 3 mins
May 20 23:46:06 sd-idle-2.6[13588]: spinning up /dev/sda after 2 mins 1 secs
May 20 23:49:06 sd-idle-2.6[13588]: spinning down /dev/sda after 3 mins
May 20 23:51:06 sd-idle-2.6[13588]: spinning up /dev/sda after 2 mins
May 20 23:54:06 sd-idle-2.6[13588]: spinning down /dev/sda after 3 mins
May 20 23:56:07 sd-idle-2.6[13588]: spinning up /dev/sda after 2 mins 1 secs
May 20 23:59:07 sd-idle-2.6[13588]: spinning down /dev/sda after 3 mins
May 21 00:01:37 sd-idle-2.6[13588]: spinning up /dev/sda after 2 mins 30 secs
May 21 00:09:37 sd-idle-2.6[13588]: spinning down /dev/sda after 8 mins
May 21 00:11:38 sd-idle-2.6[13588]: spinning up /dev/sda after 2 mins 1 secs
May 21 00:14:38 sd-idle-2.6[13588]: spinning down /dev/sda after 3 mins
May 21 00:16:38 sd-idle-2.6[13588]: spinning up /dev/sda after 2 mins
May 21 00:19:38 sd-idle-2.6[13588]: spinning down /dev/sda after 3 mins
May 21 00:21:38 sd-idle-2.6[13588]: spinning up /dev/sda after 2 mins
May 21 00:25:08 sd-idle-2.6[13588]: spinning down /dev/sda after 3 mins 30 secs
May 21 00:27:09 sd-idle-2.6[13588]: spinning up /dev/sda after 2 mins 1 secs
May 21 00:30:09 sd-idle-2.6[13588]: spinning down /dev/sda after 3 mins
May 21 00:32:09 sd-idle-2.6[13588]: spinning up /dev/sda after 2 mins
May 21 00:35:09 sd-idle-2.6[13588]: spinning down /dev/sda after 3
What can interfere? At night, only smartphones are connected to the router and even then they are in sleep mode and do not access the disk ever. All the same thing was previously connected to RT-AC66U (not B1) at 380.70.
