Extend coverage of my RT-AC86U
In case it's actually working as described on the specific hardware and firmware - may cause disconnections for clients below the threshold.
Thanks for your feedback, I have disabled the setting for both bands.
We will see if my daughters continue to complain about disconnections in the coming weeks.
However, I do not remember having set this setting, is it set this way by default ?
Bonus question: Should I expect any limitations if I use an RT-AX86U Pro as main router with my current RT-AC86U reinstalled as an AP in Aimesh ?
Yes, ASUS ships standalone routers with Roaming Assistant enabled... another reason I don't think it matters with only one AP in play.
Yes, of course... with two different generations of hardware and firmware functionality, you can expect limitations.
OE
