Extension cord for RTAC66U
  • Thread starter Thread starter Deleted member 22630
  • Start date Start date
Instead of installing an extension cord between the adapter and the wall outlet, what if you installed an extension cable between the adapter and the ROUTER?
I've made them before from parts at Radio Shack but they're readily available on the Internet. It would certainly be considerably less bulky than an extension cord.
http://www.amazon.com/dp/B00FTH6WNS/?tag=snbforums-20
I like the idea above. If not cut the cord and carefully solder a extension of very similar wire together tape with electric tape and then some heat shrink tubing. These routers dont draw big current so 7ft extra should be fine.
Wanted to add, Remember with DC voltage you must observe the proper polarity. + -
Why don't you just buy the adapter that I linked to originally (upthread) with the 14' long cord and do what we Americans would do if we took that device to Europe: Buy an adapter to fit the U.S. plug on the adapter so it fits whatever standard is used in your country? Wouldn't that be easier, cheaper and safer than cracking open the original unit, or splicing wires?
Try this link to an Amazon.co.uk search for "US Plug Adapter to European Plug".
That would be a good solution - albeit more expensive - but I forgot to mention that besides the US plug, they don't deliver to Europe.
No, I'm not going to be cutting into live wire (although I'm sure by this stage L&LD would like me to ;-)) and yes, I'm just looking for a solution to extend the cable with minimal bulk so I can fit it behind the baseboards.
Regards,
Scott.
For the record; I would not have wished that. :)
The additional details you provided may help others give better advice.
OMG, for safety reasons, do NOT hide an AC cord behind the baseboard! That is a gross safety violation!
AC "Extension cords" are meant to be temporary, visible, not hidden, not under a carpet, etc. certainly not inside your wall or behind a baseboard!
Yea, we've probably all wire-stapled some extension cord against some molding. (But hopefully not as an adult...)
Extend the DC cable from the adapter to the router, instead.
Get a small shrink-wrap tube assortment. cut the wire, splice-in an extension (you might want to use a heavier-guage wire depending on how long this has to be).
Make a proper wrapped splice (make an "x", wrap the ends along the wire in opposite directions - if you tug on it, it should tighten rather than come apart), and solder, making sure you heat the WIRE, not the solder. Heat the wire and feed solder into the junction. The junction must melt the solder, not the soldering iron.
Slip a piece of shrink-wrap tube over each wire, and a larger one over the whole thing. You should be able to make a splice with a minimum of bulge if you are careful. Slips the shrink-wrap over before soldering. ;)
For a small job like this, you can use a match or lighter to shrink the tubing. A hair-dryer is not hot enough to do the job. There are special heat guns, which are overkill for making one extension. Don't kludge it with electrical tape.
Watusi:
He's not talking about hiding an AC cord behind a baseboard.
He's talking about hiding a DC 19v cord behind a baseboard by extending the DC cord somehow.
Your other suggestions are in line with what others have previously suggested and are good ones.
Frankly, I can't believe we've all devoted this much time writing about how to splice two low voltage wires together....and I'm as much to blame as anyone for that. My apologies.
Sowen:
Seriously, Amazon.com will not deliver overseas? Really? I did not know that. I thought they'd deliver anywhere and it was just be a question of cost.
Do you know anyone in the U.S. who can buy it and ship it to you?
Watusi:
Thermostat wire is good enough for this and is meant to go in walls and on surfaces. Home Depot item.
You can get DC socket extension leads from places like dealextreme with free worldwide shipping, or your local eBay site. You just need to know the size of the DC pin. This is what I did to extend the length of the PSU for my RT-N16.
Sent from my Nokia 3310 using Tapatalk
