I recently lost an external HDD during a router upgrade. So I bought another drive to replace it. My previous drive was Seagate 3TB with external power. I also have a 4TB WD (older model) with external power. Since WD was working flawlessly my replacement drive is 4TB WD (newer model) with external power.
Now the newer 4TB WD won't mount in either port.
These are the syslogs:
Does this mean that the device is too big?
Jul 23 21:58:21 kernel: sd 4:0:0:0: [sdb] Very big device. Trying to use READ CAPACITY(16).
Jul 23 21:58:13 kernel: usb 2-2: new high speed USB device using ehci_hcd and address 4
Jul 23 21:58:13 kernel: scsi4 : usb-storage 2-2:1.0
Jul 23 21:58:14 kernel: scsi 4:0:0:0: Direct-Access WD My Book 25EE 4004 PQ: 0 ANSI: 6
Jul 23 21:58:14 kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0
Jul 23 21:58:14 kernel: scsi 4:0:0:1: Enclosure WD SES Device 4004 PQ: 0 ANSI: 6
Jul 23 21:58:14 kernel: sd 4:0:0:0: [sdb] Spinning up disk...
Jul 23 21:58:14 kernel: scsi 4:0:0:1: Attached scsi generic sg3 type 13
Jul 23 21:58:21 kernel: .......ready
Jul 23 21:58:21 kernel: sd 4:0:0:0: [sdb] 7814035456 512-byte logical blocks: (4.00 TB/3.63 TiB)
Jul 23 21:58:21 kernel: sd 4:0:0:0: [sdb] 4096-byte physical blocks
Jul 23 21:58:21 kernel: sd 4:0:0:0: [sdb] Write Protect is off
Jul 23 21:58:21 kernel: sd 4:0:0:0: [sdb] Assuming drive cache: write through
Jul 23 21:58:21 kernel: sdb: sdb1
Jul 23 21:58:21 kernel: sd 4:0:0:0: [sdb] Attached SCSI disk
Jul 23 21:58:21 hotplug[17854]: USB /dev/sdb1(unknown) failed to mount at the first try!
Jul 23 21:58:21 usb: USB /dev/sdb1(unknown) failed to mount At the first try!
Jul 23 21:58:21 kernel: tfat: fail_safe is enabled
Jul 23 21:58:21 kernel: tntfs info (device sdb1, pid 17862): ntfs_fill_super(): fail_safe is enabled
