T
thetoad30
Guest
...especially on my own dime.
Agree to that part. Maybe someday you'll come across one of the previous dual-band models and you can test it just for fun!
I purchased the latest model. But there is more to the story. Update coming soon.There is a post over on xlr8yourmac.com from a user who still claims that the new Airport Extreme is a three antenna design.
I voided the warranty the second I opened it up. Besides, I've already fixed it.Have you contacted apple to see what they say? Ask for a return since you don't think it's hooked up correctly?
Apple isn't alone in not informing customers of "known problems". Companies in general only inform customers of safety-related problems because of liability. Otherwise, it's tough noogies.
The information is in the article, i.e. swap the connections to the radio module AP3 and 4.Will you show how the antenna are supposed to be connected? Did you swap the order of the amp connectors where there are 4 in a row?
Here's the update.
More Surprises From The New Airport Extreme
Is it true that the Airport Extreme is the only usb capable router that will mount mac drives and hence be able to use time machine?
I would find that hard to believe. My understanding is that the router does not look at the actual disk content but merely relays the USB commands to access the external storage (or printer) across the local network.Is it true that the Airport Extreme is the only usb capable router that will mount mac drives and hence be able to use time machine?
Welcome To SNBForums
