sfx2000
Part of the Furniture
We get asked this all the time...
Huawei makes some great little 3G/4G/LTE USB dongles - but they're basically a bit odd to work with on Linux...
When first turned on, they present a USB Mass Storage Endpoint - this is a "virtual" CDROM device that has connection software, device drivers for Mac, Windows, and maybe an installer and/or user guides
If someone can test below to confirm (include the Huawei device model number/carrier if success or not), it would be helpful, and we can update the post accordingly.
This is all for Linux, but Windows is similar - you can use HyperTerm or Procom, or whatever...
And then the device should be permanently put into Serial mode, and it'll be fine from there.
@RMerlin - is usb_modeswitch part of AsusWRT or your builds?
- Make sure you execute these steps from a computer that can see the serial line interfaces of the device. This should be possible on any Linux computer that has usb_modeswitch installed and configured, like done by default on at least Ubuntu 12.10 (and newer).
- Find out the first USB interface of the device by doing ls /dev/ttyUSB* before and after plugging the 3G stick in and taking the first result.
- Open one terminal for receiving messages from the device, by executing cat /dev/ttyUSB1 (using your device number of course).
- In another terminal, send a command to the stick to test communication with it. Execute echo "ATi^M" > /dev/ttyUSB1. But note: You can not simply copy this over, as the ^M is just the visual representation of a single control character. Enter this character in the terminal directly by pressing Ctrl+V and afterwards Ctrl+M.
- Now, your terminal with cat should display information that the stick sent about itself.
- If this worked, now send the command to disable the virtual CD-ROM mode: echo "AT^U2DIAG=0^M" > /dev/ttyUSB1. Note that ^M is again a control character that you have to enter specially (see above), but ^U is just normal text, so you can copy & paste it.
- Now your cat terminal should answer with OK. If so, the command was successful.
