Thanks for your quick reply.
Yes, 384.13
Edit 1...
I guess the script needs minor changes, but sadly
IDK how to do that.
Edit 2...
I just read the changelog, and yes, you're right.
"- CHANGED: dhcp_staticlist no longer contains hostnames, these
have been moved to dhcp_hostnames for better
compatibility with upstream and closed source
components, also allows more static leases to be
defined before reaching the size limit."
Yes, 384.13
Edit 1...
Edit 2...
What firmware version are you using? The format of the NVRAM variable was changed in 384.13 (see the release notes).
