Feature request: VPN uptime %
BigSnicker
Just a thought, but for those of us not using exclusive VPN routing, it'd be useful to be able to log in once a week and see how effective the embedded VPN client is at staying up. Currently, I know mine is dropping once in a while, but I"m having difficulty assessing exactly how significant the problem is for a given server.
While I'm dreaming, it might also be useful to see the number of VPN failure incidents detected as well, although I'd say this would be very much optional compared to the availability %.
That would fall in the category of "feature that nobody but 2 or 3 users would use", so no.
You can monitor it yourself by using user scripts if you really need to monitor this. Just browsing the system log should also provide you with the necessary data.
Shame, but no worries. And yeah, it should be pretty straight forward to parse the logs, especially now that I've got remote logging configured.
I'll post it here if there's any interest from the other 1 or 2 people. ;-)
Yes please post...
