Still playing around with log levels and whether to include the feeds before all the filtering as well (by device / 3 more logs, might be too busy). In any case here's the first pass, have scribe, entware, scMerlin and LCD scheduler running on on the two AIMESH nodes, forwarding everything to the router. Scribe on the router setup with additional filers to better focus on specific areas for any interaction between the nodes and router. Not any real impact on the router in terms of CPU or RAM that I've been able to measure. The AC5300's are using a bit more RAM, but as nodes not really doing much to use the RAM they have anyway.
While implementing this, I did run into a few problems with a few scripts on the router in terms of losing logs, having to reinstall, turning logging off than of and so on. Eliminated the GUI for vpnmgr somehow and not even a reinstall brought it back. This was with 386.1 and now running 386.1_2, router and nodes. Post reboot, haven't tried to reinstall vpnmgr but will try again soon.
The expanded roamast log below, you can see entries for AX88U-MAIN (Router) and both AC5300's in the bedrooms, hence the LCD scheduler
- While you can turn off the LCD's in AIMESH 2.0 it doesn't carry the setting between a reboot, LCD scheduler provides consistency.
