AdGuardHome Few questions about AdGuard Home Install Script
Old thread - but I recently changed to DietPI on my RPI4 and installed Unbound along with AGH, and now DNSSEC works and passes all tests:
Not sure if this is related to the version of Unbound being updated due to now running Debian Bookworm - I know the previous version available in Debian Bullseye was a couple of versions behind.
I don’t think it was anything in my Unbound conf file as I copied that over as well…
This issue has been resolved already. It was a problem with Adguardhome not properly reading the dnssec data from Unbound once DNSSEC was enabled inside AdGuardHome (to be a bit more specific, the EDE data). DNSMASQ, and Pihole consequently had this same issue as well. Overall, it has been resolved across the board.
Ah ok.
Is the DNSSEC checkbox in AGH just something that shows the flag in the logs? Or does it also send a DNSSEC request with your lookups?
Are there any patch/release notes for AGH or Unbound that show this issue and subsequent fix?
Ah ok.
The release notes are not as detailed as say for example piholes, but here is one recent fix from adguardhome:
And another one specific for using adguardhome and unbound together :
Here is a list of some stuff:
Heres piholes :
Essentially, dnssec data was being misidentified or misinterpreted.
Actually, the user was getting the two intertwined, thus he did not understand any of it.
For adguardhome, You can modify the cache value here:
the default value is "4194304bytes" or "4mb" I chose "524288bytes" which is approximately 1/8th the default size. I noticed alot less strain on my RAM at this size (it is still using alot of ram, but the demand dropped). A good amount of cache typically ranges in sizes from 524288 to 2097152 bytes. The fact that AdGuardHome uses 4194304bytes is a bit overkill incomparison the the amount memory it already demands.
Hey,
Do you also use DNSSEC and EDNS in AdguardHome? Or just leave it alone for Unbound to work on its own?
Should I even use EDNS? Thanks
That is up to you. Unbound should use it by default since it adds additional support for larger DNS messages, DNSSEC (DNS Security Extensions), and other important DNS features, improving the overall security, performance, and functionality of your DNS infrastructure. But you shouldn't need to enable it on AdGuardHome since the requests from adguardhome to unbound are done locally. If you were sending the request to a non-local resolver (e.g. google), then yes it could be useful. If you are using more than just Unbound in your AdGuardHome upstream section, I would recommend enabling it in AdGuardHome.
Then for me it is disabled. However, I did turn on my DNSSEC option in Unbound.
Thank you for the insight
Do you want to run AdGuardHome as a local caching DNS service which includes router traffic? Is this on or off ??? Meaning what’s the best setting ?
