Files on the external USB HDD disappeared after connecting it to the router but still they takes the space
Files in the root directory of a USB drive will not be visible via Samba (regardless of the filesystem being used) unless you have allowed "guest login".
These files I have in the root are visible in samba, and yeah I have guest login option enabled. I mean that the disk doesn't display all files, even when it's connected to PC directly via USB connector.
But I guess I will need to format disk again and download those video files form trackers again, at least it's not important data, I use this disk only for movies
Files in the root directory of a USB drive will not be visible via the router's Samba server (regardless of the filesystem being used) unless you have allowed "guest login".
Which goes back to my initial thoughts about perms and access...
