Firefox https connection
Any error messages or symptoms in detail?
I don't run Merlin FW. But I can take a look at the script later today.
Yes, it seems that when ever I put the script in at the command line it just brings up the command line again. I don't get any options or anything.
Below is what I'm talking about.
bc64@RT-AC86U-B690:/tmp/home/root# sh -c "$(wget -qO - https://kazoo.ga/pixelserv-tls/config-webgui.sh)"
Thanks again for your help.
Fixed. Pls re-run the script :)
The issue was that Cloudflare has trouble connecting to kazoo.ga.
Hey @kvic, I've been having problems with your script. When ever I run the script it seems to configure all right, but when I try to load the ca file into my browser my browser keeps telling me it's not a secure connection. Any help with this would be greatly appreciated.
Do you mean when loading http://192.168.1.2/ca.crt
Screenshot?
Also beware that in Merlin 384.8, the cert now needs to be placed in /jffs/.cert/ but the new version will migrate files from /jffs/ssl/ when httpd is started or restarted.
Yes, that's what it was. The script isn't configured for 384.8. I downgraded to 384.7_2 and now it works. Thank you for the reply, Merry Christmas!
Update the script to be compatible for FW >= 384.8. When you get the chance to try, pls let me know if it works..
  • Yeah, my ISP is down right now. So I’ll have to try later. Thank you for the reply and for everything you do! Merry Christmas!
@kvic
Would it be possible to adapt the script for the RT-AX88U as well? Unfortunately it doesn't work on this device.
@kvic
Now AX88 is supported :-)
Let me know if it actually works..no way for me to test..
Enjoy yourself.
