Firewall help to block game sites
seattle
Want to block some game sites. Used key words and URL filter. None of them work. Please help.
Asus RT-AC66U 380.62
A determined user who does a little research will most always be able to defeat filtering. Sometimes it is as simple as typing in the numerical IP of a site gets around lots of filter. Running a VPN on a PC can make it difficult if not impossible to block access to sites unless additional steps are taken to block the ports the VPN is using.
Any examples to show how to use VPN to block the websites? Thanks.
I think you misunderstood my previous post. If someone is running a VPN on their PC then it is much more difficult to block their access to specific sites. All you can do is try to block them from using a VPN. Even China isn't completely successful in doing this to prevent their citizens from entering decadent western web sites.
