URL addresses management
Ok. I did the /jffs/scripts/services-start and it says "Done." then I looked in System log as soon as 10am just showed up:
Mar 3 09:59:35 watchdog: New firmware version 388.6_2 is available.
Mar 3 10:00:00 rc_service: service 3666:notify_rc restart_firewall
firewall restarted.
I tested it again, this time at 11am instead of 10am and it still removes the two URLs same as before.
Can you post the output of these commands:
date
cru l
cat /jffs/scripts/url_filter.sh
cat /jffs/scripts/services-start
The cru parameter is the lower case letter L not the number one.
Please also post the contents of /jffs/scripts/services-start
Thanks. That all looks fine so I'm at a bit of a loss. Can you post the output of this:
date +'%H'
nvram get url_rulelist
Thanks. So that looks like it's working - unless I've completely misunderstood what you've been saying.
The current time is before 11:00 so the URL Filter list is the one that also restricts youtube and roblox.
@Blackstar I've updated the services-start script in post #13 with the following two lines. Hopefully that with fix the problem of the rules not being set correctly at boot up.
# allow time for ntp to sync then set initial filter rules
sleep 60
sleep 60
Funny, I just added 30 secs sleep command and seems to be working when I saw your post. Two URLs stayed in the list this time. I should increase it to 60 secs to be safe. I timed my router's boot time to 55 secs. Thanks for all of your help!
