Firewall -Network Services Filter
Still the Network Service Filter did not restrict connection to the internet, in fact am writing this from one if the devices
I've just tried it again here and it works fine. Can you post the complete output of this command on your router please.
iptables-save | grep FORWARD
Hello ColinTaylor, see the output below
ASUSWRT-Merlin RT-AC66U_3.0.0.4 Sun Aug 17 20:10:42 UTC 2014
admin@RT-AC66U:/tmp/home/root# iptables-save | grep FORWARD
:FORWARD ACCEPT [37042385:23151706064]
:FORWARD DROP [0:0]
-A FORWARD -i br0 -m time --timestart 07:00 --timestop 23:00 --days Sun -m mac --mac-source B0:14:75:E1:2C:12 -j PControls
-A FORWARD -i br0 -m time --timestart 07:00 --timestop 23:00 --days Mon -m mac --mac-source B0:14:75:E1:2C:12 -j PControls
-A FORWARD -i br0 -m time --timestart 07:00 --timestop 23:00 --days Tue -m mac --mac-source B0:14:75:E1:2C:12 -j PControls
-A FORWARD -i br0 -m time --timestart 07:00 --timestop 23:00 --days Wed -m mac --mac-source B0:14:75:E1:2C:12 -j PControls
-A FORWARD -i br0 -m time --timestart 07:00 --timestop 23:00 --days Thu -m mac --mac-source B0:14:75:E1:2C:12 -j PControls
-A FORWARD -i br0 -m time --timestart 07:00 --timestop 23:00 --days Fri -m mac --mac-source B0:14:75:E1:2C:12 -j PControls
-A FORWARD -i br0 -m time --timestart 07:00 --timestop 23:00 --days Sat -m mac --mac-source B0:14:75:E1:2C:12 -j PControls
-A FORWARD -i br0 -m mac --mac-source B0:14:75:E1:2C:12 -j DROP
-A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i ! br0 -o eth0 -j DROP
-A FORWARD -m state --state INVALID -j DROP
-A FORWARD -i br0 -o br0 -j ACCEPT
-A FORWARD -i eth0 -p icmp -j DROP
-A FORWARD -m conntrack --ctstate DNAT -j ACCEPT
-A FORWARD -i br0 -j ACCEPT
cheers mate
That output shows that you are using Parental Control! This discussion is about Network Services Filter.
UPDATE: OK It looks like you can't have Parental Control and Network Services Filter both active at the same time.
  • Like
Reactions: erb
Sorry mate - I forgot to that I remove the Network Service Filter last night - please see output -
RT-AC66U login: Admin
Password:
:FORWARD ACCEPT [37482672:23572138956]
:FORWARD DROP [0:0]
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Sun -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestart 23:00 --days Sun -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Mon -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestart 22:30 --days Mon -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Tue -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestart 22:30 --days Tue -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Wed -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestart 22:30 --days Wed -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Thu -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestart 22:30 --days Thu -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Fri -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestart 22:30 --days Fri -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Sat -j DROP
-A FORWARD -s 192.168.1.102 -i br0 -o eth0 -p tcp -m time --timestart 23:00 --days Sat -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Sun -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestart 23:00 --days Sun -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Mon -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestart 22:30 --days Mon -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Tue -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestart 22:30 --days Tue -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Wed -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestart 22:30 --days Wed -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Thu -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestart 22:30 --days Thu -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Fri -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestart 22:30 --days Fri -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestop 06:59 --days Sat -j DROP
-A FORWARD -s 192.168.1.103 -i br0 -o eth0 -p tcp -m time --timestart 23:00 --days Sat -j DROP
-A FORWARD -i br0 -o eth0 -j ACCEPT
Well those settings are identical to mine and it works for me.
So unless you had accidentally left Parental Control turned on I can't see why it isn't working.
The only possible causes I can think of:
1) You're WAN interface isn't eth0 (i.e. you're using a VPN or 3G modem to connect to the internet)
2) The client IP addresses are not 192.168.1.102 and 192.168.1.103 (a mistake in DHCP or perhaps because you're using a wireless repeater)
3) The clients are on a guest wireless network (just a guess)
4) There's a bug in the iptables version on the AC66U that isn't on the N66U version.
5) something else....
I'd say this -"So unless you had accidentally left Parental Control turned on I can't see why it isn't working." - which I have removed now and will report back later based my my selected times
Hello CollinTaylor - the devices did disconnect from the internet within the specified time, so just like you said NSF does not work when PArental control is defined also - I do appreciate your time / input
Cheers
You're welcome.
I don't know whether that behaviour is a bug or by design. Maybe RMerlin can tell us?
If it's meant to be like that then I think there should be a warning somewhere in the GUI, because it's not obvious. :(
This is why my network services filter was not working, I had to turn off parental controls! Thanks :)
Looking for closure
Did we get definitive answer yet?
//been grateful for Merlin efforts, all around//
Parental:
I want to block a printer from ET-phoning-home on cartridges so I use parental controls for broad time based access (deny all)
NSF:
I NEVER want my devices using goog-8.8.8.8/4.4/etc, so I want to use specific destination filtering.
Now I'm reading that:
* NAT H/W Accel cannot be leveraged with one or both of these other services?
* Parental interferes with NSF?
STATIC:
I've also seen workarounds for static routes back to LAN IP w/ metric of 2 which returns unreachable response...
Can I use NSF for all above and not have to disable H/W accel? (would be nice to have all offered services work in harmony?)
Grazie/ciao,
Enzo
@Enzo As far as I am aware the problem the NSF and Parental control conflicting with each other was fixed long ago.
Just looking quickly at your NSF rule, you are blocking only UDP. Ping uses ICMP.
Colin
#Whoa! (blush)
Thank you (deleting prior thread, to not waste forum time)
