firmware mod kit does not do the job
It is possible that my Windows has been infected while dnsmasq was crashing. I don't know for sure if it was infected, it might have something to do with a crack for DVDFab, or it might be a perverse effect of installing VMware. What I know is that I lost keyboard and mouse control over Windows. I have restored Windows several times from backup and after an hour or so I lost every time keyboard and mouse control over Windows. I have then restored from an older backup and it no longer happens.
Anyway, virus infection is not an excuse for dnsmasq dying under stress.
Yes, I bought the computer with Windows on it. The present Windows is however, downloaded, but the license is real.
I have scanned the supposedly infected system with Bitdefender for Linux and it could not find any infection.
It could also have something to do with this: https://sha7rour.wordpress.com/2011...gning-in-windows-7-using-group-policy-editor/
I.e. something might have enabled driver signing without ignoring errors, and this might have been the cause of losing control over Windows. But I do not know what might have enabled driver signing (MBAM? not sure about it).
This is rather off-topic for this thread (and the whole forum actually), as this has nothing to do with your router.
Ok, getting back on the horse:
I did:
#!/bin/sh
sed -i -e 's/\:\:/::1/g' ab-solution.sh
sed -i -e 's/0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa/1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa/g' ab-solution.sh
Then I have edited as follows:
# diff ab-orig-sedded.sh ab-solution.sh
--- ab-orig-sedded.sh
+++ ab-solution.sh
@@ -1885,8 +1885,9 @@
        if [ $ipv6_service == "disabled" ];then
                address_append=""
        else
-address_append="pc_append "address=/::1/::1" \$CONFIG
-pc_append "ptr-record=1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa,::1" \$CONFIG"
+               address_append=""
+#address_append="pc_append "address=/::1/::1" \$CONFIG
+#pc_append "ptr-record=1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa,::1" \$CONFIG"
        fi
 else
@@ -1895,8 +1896,8 @@
        else
 address_append="pc_append "address=/0.0.0.0/0.0.0.0" \$CONFIG
 pc_append "ptr-record=0.0.0.0.in-addr.arpa,0.0.0.0" \$CONFIG
-pc_append "address=/::1/::1" \$CONFIG
+#pc_append "address=/::1/::1" \$CONFIG
        fi
 fi
 # add blocking files and blocking IP to dnsmasq only if ad-blocking is on
Then I have updated the ab-solution hosts. Then I have flashed John 25E1. But dnsmasq still dies when doing Zemana Antimalware. I have reverted back to 25E1 with dnsmasq from April 22.
More than 90% of the hosts you won't hit during your lifetime. It's insane for a home. Is your dnsmasq serving a large local community?
That's a lot of hosts - wonder how many of them are actually duplicate entries, or hosts that can be covered with a CIDR range rather than just IP - this is more relevant these days given the cloud...
Repetitive duplicates are easy to remove. I think everyone is doing that already. So consider all those numbers unique.
