Any reason not to use John's User NVRAM Save/Restore Utility to save and restore your user settings after the upgrade and factory reset?...not have to a factory reset, do I need to take one upgrade at the time and go through the whole list to avoid factory reset?
Running 376.47 on asus RT-N66U, I want to keep all my settings and not have to a factory reset, do I need to take one upgrade at the time and go through the whole list to avoid factory reset?
Ok guys, so I can just go with the latest update then do a factory reset and it'll be good to go (I need to add the settings and stuff I had before)
So it'll be 376.47 to RT-N66U_380.64_0
From .47 to .64 you probly need a intermediate flash if your upgrade fail at the first attempt.
Reboot,flash with 378.55 and 380.64 after
Welcome To SNBForums
