I agree. Home PCs don't belong in a business. Too many bells and whistles to break. Dell has plenty of PCs designed for businesses. I will be happy when I can replace these last 2 home PCs at my daughter's business. The whole shop was full of these things. I think the PO went around buying home PCs on sale for his business.
If you buy all the same PCs it sure is easier to support. They tend to behave all the same. You don't end up trouble shooting individual problems for each different PC.
We have run into a problem with T-Mobile. My daughter has 3 T-Mobile real estate agents which get poor service. They have contacted T-Mobile and were given extender boxes which do not work and T-Mobile seems not to be able to fix their boxes. My guess is the boxes are some how cancelling out each other but the agents have to go outside to use their T-Mobile phones. AT&T works fine.
So now I am planning a wireless upgrade to my daughter's wired only network to support cell phones. I am going to isolate the wireless from the wired network for both security and speed. I plan to install a Cisco layer 3 switch. I will build a router VLAN which will be my high speed core for the network as she does not have any servers. Traffic will be routed to the core based on speed. Slower wireless can be routed at it's slower pace. Nothing will slow the core. There will not be any broadcast from Windows workstations or anything else. The high speed core is a point to point from the switch to the internet Cisco router.
I will have to wait and see the total over all bandwidth impact from the cell phones. Hopefully we don't have to jump to the next higher internet service. Voice should not be that big of impact but once you get 15 agents on wireless who knows.
No the T-Mobile boxes are the old not supported ones and you need 1 box per phone with a receiver station. They are sending 1 of the new ones. But we might go with wireless.
I am still thinking of putting a Cisco wireless AP in to support Wi-Fi calling across the board. I don't know what the impact of 15 users doing Wi-Fi calling would have on the internet bandwidth. Seems like voice calls should be a small amount of data packets.
The cell spot I am using seems to maintain a VPN to their network so Wi-Fi calling may be a better solution even though I am going from 3 users to 15.
I think I will use the separate VLAN I created for the cell spot for the Cisco wireless AP also.
Welcome To SNBForums
