FlexQoS FlexQOS faulty insstallation instruction
Squall Leonhart
Using the installation command listed on the github breaks because the full write path isn't specified, if an addons directory already exists curl fails with IsDirectory.
Deleting that directory installs the .sh as "addons" txt file without a shell extension.
admin@RT-AC88U-9670:/jffs# /usr/sbin/curl "https://raw.githubusercontent.com/dav
e14305/FlexQoS/master/flexqos.sh" -o /jffs/addons
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
Warning: Failed to open the file /jffs/addons: Is a directory
Simple fix, change to
/usr/sbin/curl "https://raw.githubusercontent.com/dave14305/FlexQoS/master/flexqos.sh" -o /jffs/addons/flexqos/flexqos.sh
I updated the README on github so it offers the small “copy” button at the end of the text to be copied.
But the preferred installation method is via amtm.
I can't get flexqos or cakeqos to work
Router RT-AX58U_V2
Router RT-AX58U_V2
Not a surprise with Gnuton’s firmware. What’s the output of:
tc qdisc
nvram show | grep -E "^wan.*ifname="
The Asus Normal qos doesn't work either, even if it is with the stock firmware, it always sends the traffic to these 3 classes even if it is playing Netflix Twitch, it doesn't matter.
Was any QoS active when you ran those commands? If not, activate Adaptive QoS and run them again.
¿Había alguna QoS activa cuando ejecutó esos comandos? Si no es así, active la QoS adaptativa y vuelva a ejecutarlos.
FlexQos the previous one was with cakeqos
No matter the traffic is directed solely to this class.
With the factory firmware, adaptive QOS happens the same, it does not detect the applications.
It should detect games, Netflix, downloads, etc.
I already did a reset and tried several firmwares and I can't find the solution.
The FlexQoS screenshot shows the AppDB rules with many “undefined” entries, which suggests that the Trend Micro signature files are not “complete”. How many lines in /tmp/bwdpi/bwdpi.app.db
La captura de pantalla de FlexQoS muestra las reglas de AppDB con muchas entradas "indefinidas", lo que sugiere que los archivos de firma de Trend Micro no están "completos". ¿Cuántas líneas hay en /tmp/bwdpi/bwdpi.app.db
admin@RT-AX3000-56C0:/tmp/home/root# Permission denied
-sh: Permission: not found
Please post:
wc -l /tmp/bwdpi/bwdpi.app.db
admin@RT-AX3000-56C0:/tmp/home/root# wc -l /tmp/bwdpi/bwdpi.app.db
721 /tmp/bwdpi/bwdpi.app.db
Please post:
head /tmp/bwdpi/bwdpi.app.db
Please post:
admin@RT-AX3000-56C0:/tmp/home/root# head /tmp/bwdpi/bwdpi.app.db
0,6,0,IRC
0,49,0,Message Send Protocol
1,2,0,BitTorrent Series
1,4,0,DirectConnect
1,62,0,eMule
1,113,0,XBT Client
1,145,0,PowerFolder
1,146,0,KNOwShowGo P2P
1,189,0,Transmission
3,1,0,FTP Applications
How about:
grep -E "^(0|13)," /tmp/bwdpi/bwdpi.app.db
ASUSWRT-Merlin RT-AX58U_V2 3004.388.7_1-gnuton1 Mon Jun 10 09:50:03 UTC 2024
admin@RT-AX3000-56C0:/tmp/home/root# grep -E "^(0|13)," /tmp/bwdpi/bwdpi.app.db
0,6,0,IRC
13,222,0,HTTP
0,6,0,IRC
13,222,0,HTTP
Please can you give me information if there is any problem and if there is a solution?
Have you tried checking for a Signature Update on the Firmware Update page? Either your signature files are obsolete, Adaptive QoS has lost a lot of intelligence, or the Gnuton builds are broken.
I tried and nothing, I'll put another router.
Thanks for the help
Thanks for the help
I just tested this today, and I see the same issue with the latest signature update. So it’s not just your router.
