Tutorial Forcing SafeSearch Tutorial
What I meant by a script is....
Since I have been told that running a recursive DNS server opens the door for security risks...
So the script I am referring to, is one that closes any ports it opened or whatever it is Unbound did....I am saying "opened ports" as an example.
If there is no script, what do I need to do, to make it as secure as it was before I installed Unbound?
You have a miss understanding. What I mean is trying to create an "open dns" server. If you are not manually opening any ports directly to your self you should be fine. There is no script to teach proper networking and internet best practices. This is knowledge you yourself must acquire.
Sorry, I just got confused because I thought there was something Unbound changes on my network that would make it less secure... so I wanted to know what is it I needed to do to overcome that.
Last question...
Let's say I don't open any other ports or make any changes to my configuration...
Is my network less secure by running Unbound as a recursive DNS server or there would be no change?
Last question...
It doesn't change any thing that makes you less secure than any other method on the market. Especially in regards to following proper internet usage best practices. What makes it become "truly unsecure" is to use it internet web facing with no firewall in-between. Or not using good web browsing practices. Essentially, if you don't know what you are doing or have no regard for good internet practices, you probably should just turn off your internet access because the same or similar vulnerabilities exist for all methods absent of proper regard for internet best practices.
I guess since I don't know what I am doing and apparently don't have any internet best practices, I will just turn off my internet, just to be kind of safe.
Thanks for answering my questions.
As previously mentioned internet best practices is not something that can be given in a script. Examples of such would be -"Don't click unknown links on the web." Or "Don't visit places with bad reputations." Those are just a couple of good practices. Just because you run a recursive server, or not, does not mean you will not fall victim to either if you are not using good practices. To say you are not going to use a recursice server because you might click on a bad link is like saying you just shouldn't use the internet because you might click a bad link. It all boils down to are you following good internet practices.
Your Unbound related questions were answered already few times by different people in different threads.
I know I don't have much knowledge when it comes to networking, hence why I am here. Even with my limited knowledge, I am pretty good at least with those internet best practices.
But, I also read, with a recursive DNS server, if I don't have it configured correctly, I can become a victim of DNS cache poisoning among other attacks.
I understand whether I use a recursive DNS server or not, just by using the internet, I can be a target.... yes, I get that!
But a response saying..."if you don't know what you're doing.. then turn off your internet"...
To me that doesn't really help the user. I completely understand where you're coming from, I get it.
It's difficult to deal or try to help someone with very limited knowledge and I am always grateful when users try to help folks like me, so thank you.
I don't think they were answered. I got answers, but I believe the answers did not address my questions.
Some users recommend Unbound, but when I ask questions as to what to do to mitigate the risks of using Unbound, I get for the most part..
"if you're worried about risks or security, turn off your internet"
but never really gave a solution of what I need to do to overcome those risks.
But again, I understand . Thanks all for trying to help.
Someone with very limited knowledge doesn't need Raspberry Pi with Pi-hole and Unbound.
This forum doesn't give you knowledge. It can give you advice only. You have to read and improve your knowledge yourself and only then you'll start understanding the answers given to your questions. You chase some "security" and "privacy" ideas without good understanding what both mean when your router is connected to Internet. From what I have seen so far in few threads - my advice to you is written above.
This is the type of answers I am referring to. (I don't own or use a Raspberry Pi) Thanks for your input.
I gave plenty of solutions like "don't click links you don't know or trust" and "make sure your unbound instance isn't directly web facing with no firewall between". All of these are critical tips for mitigating the risk of cache poisoning possibilities. Other risks such as the "risk of the unknown" plagues every method equally.
Here is a good read for you:
And another:
You don't need to pull your internet connection to be safe. As mentioned in other posts, the security a router does is only partially liable to the security of the network as a whole. With the user being the most insecure thing about it.
Still no script that will help in your quoted scenario above.
Glad to see you're still learning (and willing to learn). Keep doing that. Maybe read some of my links, which include not using default ports for a default setup.
The internet by design is built on trust. Whether one knows it or not. Either you trust certain sites, or you don't. But nothing you can put on a router or other network device will give you free rein for surfing the internet and keep you totally safe too. You must decide the balance.
For myself (as I've stated before), I don't trust anything on my phone (Samsung/Android). No apps. No games. Nothing except phone/text use. Why? Because Google is behind everything on that platform. And I don't trust/refuse to allow Google into my activities.
On the computers, I don't randomly follow every link. I never click on any 'Ad'. I don't use Google to search for what I want. I have a handful of sites that I use and pretty much stay within them (and even that isn't 100% secure, I know). I also don't have third-party Antivirus software either for the same reason (I don't trust any third-party provider - and, when I did, that is the only time my computers would be infected... coincidence? I don't think so).
On that same note of entities I don't trust, Apple is right up there with Google. I really want another choice for a phone (iOS and Android really suck for what I use them for).
For your search, learn as much as you can about the things you want to know about. Unbound? Sure, you can be reading for a few weeks on that alone. When you've absorbed all that information, make your choice then. No script can help with that. Nor can anyone here or on any other forum answer that for you.
Start with the basics. Keep it handy (even print it out if that helps you better). But know that anything you do is a tradeoff when you're online. You either want some information from the web, or you don't. I lean towards the 'don't' side myself, and I don't feel I miss anything.
Unbound.conf
I understand sometimes is a bit more difficult to explain what one is asking when the correct terminology isn't used and I apologize about that.
This is an example of that I would need help with. How can I make sure this isn't the case?
Or, is this this something that unless I manually make a change to Unbound, I should have to worry about it?
Again, if this is something you don't want to get into, I can understand.
I try to read as much as I can and research, but when I don't understand or comprehend what I am reading, I ask for help.
I wish I had more knowledge and didn't have to depend on others...but the effort is greatly appreciated.
Unbound.conf
Thanks @L&LD, I said script just because that is terminology I am familiar with...but it doesn't have to be a script. I think I made my question more difficult because I used the wrong terminology haha.
Well my point is as long as you are not doing any of my previously mentioned "don't do's" your risk of cache poisoning is as equal as it would be with any other dns method since most dns cache poisoning protection mechanisms are built within the server.
That is one of the benefits of learning/researching the 'language' of the area you're interested in too. Because it is important and specific.
Happy reading! Keep great notes. Review them occasionally and update your notes as your knowledge increases too.
I'll quote the most important part of my reply to you below. Because that's how important it is.
You never answered the question what's the idea behind your Pi-hole and Unbound adventures. What's your router not doing enough for you?
Thank you @SomeWhereOverTheRainBow. All of you have been very helpful in the past with all my other nonsense haha.
I guess I was expecting an answer like ....
for example... When I asked about how to mitigate the risks of using Unbound, I was expecting something like...
To attempt to mitigate those risks, you need to make sure THIS and THAT is setup properly.
to do that, you need to do THIS.... "whatever THIS is".. close ports, add some firewall rules and what not.
This is what I was referring to when I mentioned scripts, but it doesn't have to be.
But, if you're saying as long as I don't click on unknown links and follow the "don't do's", then I should be fine..
Please understand, I am aware that it won't matter what firewall rules I have in place, If I am not careful then it doesn't matter.... I get that.
I just wanted to make sure my question was understood of what I was asking for.
I know I have a lot to learn, but, sometimes you read and don't understand or comprehend what you're reading.
But this has gone long enough haha.
