Hi John, would you consider backporting dropbear support for ed25519 keys? I converted all my SSH keys from RSA to ed25519 during my latest stint on Merlin. I realize now when I come back to the fork, I can’t use them. Themiron’s commit is here: https://github.com/mkj/dropbear/commit/3d12521735e7ef7e48be217af0f27d68e23050a7
Saves nvram space and considered more secure! :)
I'd almost be willing to bet you're the only one that has done this :)
There's a build for you to try in my private downloads.
As far as nvram space, you can move the key to jffs. See the Merlin_Fork_Options.txt file
Excellent! I missed my "maintenance window" for today, but I will try to report back soon.
I was just trying to make it sound more appealing for the entire user base, instead of being a selfish request to make my life easier. :p
Looking at the code the alias_llmnr appears to do nothing (there's a TODO comment) and alias creates a CNAME for the real name. Don't what the implication of that is as I don't use Avahi. (Although I can't actually find the part of the source code that creates those two lines in the config so I'm missing a piece of the puzzle somewhere.)
So, a data point.. these entries are not added to the generated configuration in 43E6 - it becomes standard afterwards I presume when avahi 0.7 is added/updated. From what I can gather, alias_llmnr is probably related to Link-Local Multicast Name Resolution which is the Microsoft implementation of mDNS. From what I can tell, this is a relatively narrowly supported implementation so that it doesn't do anything yet I suppose isn't surprising? I'm not a windows guy, I have zero idea what they might use that for. Apple uses Bonjour for a number of things including AirPrint, AirPlay, AirTunes, etc.
I haven't yet figured out what the reasoning behind/userfuless of the alias/CNAME is.
I took the fork in the road and my ed25519 key is working well. Thank you for indulging me!
Actually, it was...just not in the right place:oops:
There's a fixed build up....thanks for checking it.
"Fixed" build? Is it in the dev directory or elsewhere, I don't see it yet?
Not having any issues with the current build...so I'll shut up.
Hi Guys,
Thanks John for maintaining this! works great on my RT-N66U, however I noticed the router is doing a lookup for www.google.com every 5 seconds or so, anyone knows why the router is making this call every 5 seconds?
Also, have you guys found a way to advertise another DHCP settings (main for start/stop IP and DNS) for GUEST networks?
Thank you,
How are you determining it comes from the router itself versus from a LAN client? Do you have any dual-WAN enabled? wanduck has a reference to "www.asus.com www.google.com www.baidu.com www.yandex.com". Do you see queries to all these domains or just www.google.com?
I have Pihole installed and pointed the router to Pihole , this is what I see:
PS: Dual Band is turned OFF.
Cheers,
I doubt the router would generate AAAA queries. Is is possible you have clients using the router IP as DNS and the router is forwarding those requests to the Pihole? A very common problem depending how you setup pihole in the router (as LAN DHCP DNS or WAN DNS).
