Forward Protocol 50?
uglyslate
I just came over from DD-WRT to Merlin for my RT-N66U.
One of the things that I need to allow for my Azure Point-to-Point VPN is Protocol 50. However, it does not appear working with the same settings as I had in DD-WRT.
Below is my current configuration.
attachment.php
The only thing I came up when I searched was this thread which basically shows the same setup.
http://vip.asus.com/forum/view.aspx...U&id=20121210183522502&page=1&SLanguage=en-us
Is this supported in Merlin's firmware?
attachment.php
Set protocol to "OTHER". "BOTH" does what it really should do, meaning handle only TCP and UDP, while OTHER can be used for other IP protocols.
Thank you for the quick response. Changing it to "other" allowed it to connect.
