charlesbuzz
I just change my AC86U for a AX86U, I redone the config by hand, no export import
I no longuer able to connect to a device that is in a guest network (from my internal network lan or wifi)
is there something to enable that I missed ?
the guest network has access to the intranet (but in my case, I'm trying from the other side from the internal to the guest)
EDIT: i'm running the stock firmware
thanks
thanks
