Everytime when I change something I reboot the router.
Please take a look:
When I create a /jffs/configs/vsftpd.conf exactly as follows:
I reboot the router and /etc/vsftpd.conf has been changed - the content of the /etc/vsftpd.conf is the same as given above.
But despite these entries, logs and even the listen_port=874 parameter does not work.
Although I used this listen_port=874 parameter via /jffs/configs/vsftpd.conf.add, it worked ok
Mmaybe something when executing a script or /jffs/configs/vsftpd.conf without the ".add" function is not working OK
Please take a look:
anonymous_enable=NO
nopriv_user=root
write_enable=YES
local_enable=YES
chroot_local_user=YES
local_umask=000
dirmessage_enable=NO
xferlog_enable=YES
syslog_enable=NO
connect_from_port_20=YES
use_localtime=YES
listen=YES
pasv_enable=YES
pasv_min_port=57530
pasv_max_port=57560
tcp_wrappers=NO
max_clients=5
ftp_username=anonymous
ftpd_banner=Welcome to ASUS RT-AC86U FTP service.
ssl_enable=NO
vsftpd_log_file=/mnt/USB/vsftpd.log
log_ftp_protocol=YES
dual_log_enable=YES
xferlog_file=/mnt/USB/xfer.log
listen_port=874
