drinkingbird
Part of the Furniture
"N-Only" doesn't disable legacy basic rates, so the beacon is still transmitted in DSSS, not OFDM... this is so that legacy BSS's can see the beacon and management frames (including CTS/RTS) so that they don't get stepped on.
Due to a "quirk" in 802.11n - N-only mode may go into protection if there is even a sniff of legacy B/G anywhere near by - an old HP wireless printer over at the neighbors house for example - and you'll see this as non-HT stations present with the field set to true (1).
G/N mixed operations - what this does is set the wireless radio to OFDM only mode, and the basic rate starts at 6, and follows the OFDM rates up - remember in Wireshark and other parsers, when you see 6(B),12(B), etc, this does not mean it's in 11b mode, that just says it's the basic rates...
Anyways...
Going back to Asus and the WL closed source driver - not sure how the Asus WebUI scripts initialize the driver, so I can't comment on that too terribly much, other than report what I observed - over in the basic settings, there is the switch to disable 11b mode, and that was causing issues with clients not being able to properly attach. Toggling that switch back to enabled, then things were fine - note that the router was set for WPA2, not mixed WPA/WPA2...
For devices that use hostapd - things there are a bit more straight forward, as long as both hostapd and the drivers are fairly recent - OpenWRT for example, changed the default settings for legacy a couple of years back now - I'd have to look for the commit over in Master, but it's there...
At some point some of the options disappeared in the basic screen. On my AC1900 it now offers "auto/N Only/Legacy" as really the only settings. b/g protection is automatically enabled and greyed out if you change it to N only. So I guess they leave 5.5 and 11 enabled for compatibility but attempt to protect from/reject B and G devices using protection. "N Only" does disable several of the legacy basic rates, the ones below 5.5 obviously, so that is definitely helpful.
I have noticed very old draft-N devices like my blu-ray player won't connect if 5.5/11 are disabled, so I'm guessing that is probably one reason they don't remove it. I can remove them via WL and everything connects except that device (and I suspect my old HP N printer which was also probably draft-N, but that is hardwired so I haven't ever tried). So essentially you can force G/N Mixed still but it has to be done using WL command and script and may prevent older/draft N from connecting.
Yes I realize the B there is for basic rate not 802.11 b
I do find having my outdoor AP with minimum rate of 12 works well, my phone does not attempt to hang onto it as I drive down the road or go back into the house. It actually probably works better than the minimum RSSI feature which I also have enabled and pretty aggressive.
