I've wondered about that too and never been able to find anything, would be interesting to hear if someone knows.I see a lot of blame for Apple devices in this topic.
What else then SSID and password do Apple devices store about a network (and which might break connectivity)?
I remember having to do that with a Windows laptop as well many years ago (so this may have changed with Windows 10). There was a bug in the RT-N66U wireless driver, and after Asus updated it on the router, the laptop needed the network to be forgotten for it to pick up the change.#3 from Apple themselves listed under "Before changing the settings on your router". They don't say why.
3. On each device that previously joined the network, you might need to forget the network to ensure that the device uses the router's new settings when rejoining the network.
https://support.apple.com/en-us/HT202068
Absolutely confirmed. One of my Apple devices would not connect to my reflashed AX86u with SSID I was using for the last 15 years, and it connected to the same AP as soon as introduced a new SSID.
Since then I learned my lesson and after recent "nuke and pave" FW update on my routers, I created new SSIDs - while used my old impossible to retype password- and that worked, no issues of connecting any of 20+ devices (no, not all of them are iPhones
Not only Apple devices it will happen to any devices if you retain the old SSID/password to a different AP/hardware, not always but it happens.I see a lot of blame for Apple devices in this topic.
Genuine question here, not trying to be snarky, but why is the process of resetting ASUS router to factory defaults often recommended on this forum so weirdly complicated? <snip>
exactly the correct approach - fix the device...Apple saves network details in your iCloud keychain in addition to just on the device. When you "Forget this network", it removes it from both locations.
www.snbforums.com
We use essential cookies to make this site work, and optional cookies to enhance your experience.
