getting this message every 5 seconds in my log. Please help
geoffroyg
I am getting every 5-6 seconds this message in my log on Asus AX86U,
Anyone knows what this refers to?
Thank you
Apr 17 22:48:44 kernel: CONSOLE: 166402.839 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:48:49 kernel: CONSOLE: 166407.905 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:48:55 kernel: CONSOLE: 166412.965 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:48:59 kernel: CONSOLE: 166417.032 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:04 kernel: CONSOLE: 166422.095 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:09 kernel: CONSOLE: 166427.158 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:14 kernel: CONSOLE: 166432.431 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:19 kernel: CONSOLE: 166437.494 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:24 kernel: CONSOLE: 166442.558 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:29 kernel: CONSOLE: 166447.620 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:34 kernel: CONSOLE: 166452.684 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:40 kernel: CONSOLE: 166457.747 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:44 kernel: CONSOLE: 166461.813 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:49 kernel: CONSOLE: 166466.875 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:54 kernel: CONSOLE: 166471.935 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:49:59 kernel: CONSOLE: 166476.996 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:50:04 kernel: CONSOLE: 166482.269 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:50:09 kernel: CONSOLE: 166487.330 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:50:14 kernel: CONSOLE: 166492.391 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:50:19 kernel: CONSOLE: 166497.452 wl1: wlc_iovar_ext: dump: BCME -23
Apr 17 22:50:24 kernel: CONSOLE: 166502.515 wl1: wlc_iovar_ext: dump: BCME -23
I am getting this in my log now as well. Do you have a Guest network enabled? I think I started seeing this after I enabled Guest Network 2 fo r the 2.4 GHz bandwidth. More research needed.
Edit... Not related to Guest Network. I removed the Guest network and the messages still get generated every 4-5 seconds.
Edit2: Oddly, I switched my Guest Network from #2 to #3 and then rebooted the AX86U. So far, I have not seen any of the log messages after 30 minutes.
I've never enabled guest on my network and I get that message.
Yeah, I suspect its not Guest Network related. However, after rebooting my AIMesh routers, the message no longer appears for some reason.
