I recently upgraded my router to an ASUS AX11000 and modem to a Netgear 2050. Both rate for gig plus connection. I’m using cat8 cables. I’m running the internal speed test on the router itself (I also change servers just in case). I’m only seeing 940 mbps with a 1.2 gbps plan. With over provision I should see 1.5 gbps. I’m also not seeing more than 300-400 mbps on Wi-Fi with my Wi-Fi6 devices when on the 5G connection up close to the router.
any advice on settings or steps I should take.
