Recently finished install on a home 802.11n / gigabit network. I've been testing the network post install with LAN Speed Test, and I'm encountering a couple of issues.
My set-up is as follows:
For example, from the Macbook to the iMac I see the following:
Wifi (802.11n)
Thunderbolt gigabit ethernet
I can't for the life of me figure out WHY the numbers are so ridiculously different. Im happy with the read speed obviously (it's not ideal, but it's pretty fast), but the write speeds just suck. If I could bring them inline with my read speeds I'd be happy, but can anyone tell me why this might be happening? The thing that gets me is that it happens on 802.11n AND gigabit... if it was just wired I could assume maybe I had a bad 3/6 pin somewhere, but the wifi seems to point to something else...
Thanks in advance for any help.
rt
- The Synology read/write speeds are half what I can get to other devices (which I'm assuming is partly the WD green 5400 RPM drives),
- No matter WHAT I do (cable replacement, etc.) I cannot get the write speeds anywhere near the read speeds.
- Motorola NVG589 (uverse gateway, gigabit lights active)
- Synology ds207+
- iMac (Snow Leopard, 10.6.8)
- Macbook Pro (Yosemite, 10.10.1)
Wifi (802.11n)
- Write Time = 109.0403477 Seconds
- Write Speed = 7.3367360 Mbps
- Read Time = 14.7147356 Seconds
- Read Speed = 54.3672720 Mbps
- Write Time = 12.4143649 Seconds
- Write Speed = 64.4414800 Mbps
- Read Time = 1.0175524 Seconds
- Read Speed = 786.2002960 Mbps
rt
