Global Traffic Monitoring Not Working
Angst
I'm running 380.65 on my RT-AC66U and while Per-Device monitoring is working fine (love it!), the Global monitoring for 24hr, Daily and Monthly show no data. Global Real-Time seems to be working fine.
NAT is disabled. I'm saving data to a USB Flash drive.
Ideas?
Thanks!!!
Ideas?
Thanks!!!
You might need to reset the data files location. Create or reset data files: Enable if using a new location, set to Yes.
Yeah, I was hoping to avoid that; would like to hang onto the data if I can. Sigh! And thanks for the reply, btw!
I had the same thing happen. Just repoint the save location for the data and it will work again. I didn't lose any data.
