TrollyDeSarre
Hello friends,
i have a bad performance when using wireguard client protocol inside asus router- download speeds ~180mbps
when using ovpn client protocol inside asus router ~800mbps
when not using any vpn ~ 1 000mbps
i can remember, that the original asus fw had ~400mbps with surfshark wireguard client protocol enabled inside asus router
i am on win11x64pro24h2
fritz box 6690 cable (only used as a modem ) isp: vodafone down: 1 GBit/s up: 50MBit/s
connected to my Asus RT-AX82U v1 with current 3004.388.7_1-gnuton1 firmware and surfshark wireguard client protocol
PC is connected to Asus Router via an CAT 6A cable, so the Asus Router to the Fritz.Box
VPN Provider is Surfshark
When using the Surfshark App for Windows, i get ~700mbps
upload speeds are always the same ~50mbps
i played around with the MTU (windows network and in the routers wireguard client tab)
its 1387
ipv6 is completely off, from the fritz box over to the asus router to the windows network connection.
QoS in Router is disabled (when enabled, download performance even worser)
what can be done here?
thanxx ^^
its 1387
thanxx ^^
