First off, my problem is that my cable modem will not connect with my ISP with both Actiontec
ECB6200K02 adapters connected in.
Here's what I did:
1. On modem/router end, connected Actiontec adapter...ISP cable into adapter, adapter into modem cable input. Powered it up without connecting to my router, and all was good so far. Modem connects with ISP fine.
2. On TV end, put in adapter. Connected cable from wall into adapter input, and adapter output to the TV amplifier power supply that then goes to TV.
3. Powered up the TV end adapter, and the "cable" light is on for both adapters, indicating that they are connected via the cable TV coax in the walls.
4. Came back to my modem/router end and saw that the cable modem was no longer connected to my ISP, so no internet of course.
5. Pulled power connection on the TV end, and still cable modem would not connect again. Took the adapter at the TV end out entirely, and cable modem will connect. Note that the adapter at the modem/router end is still connected and powered up.
Any ideas of what might be blocking my cable modem from connecting to my ISP when the adapter on the TV end of the line is connected? That adapter, the TV end one, doesn't even have to be powered up (apparently) to prevent my cable modem from connecting to my ISP, which is pretty mysterious to me.
I did reset both adapters, before removing the one on the TV end, to see if that would have any effect, and nothing changed. I also tried connecting the adapter at the modem/router end to a LAN port on my router, no change in behavior there, either (wasn't expecting it *smile*).
I should add that I have used MoCA 1.1 here very successfully, but that was before the cable amplifier for the TV was installed, as I recall...the TV amplifier is outside, and the power supply for it along with the connection for the TV (on the power supply brick) is inside. Don't know if the amplifier could be affecting things. I need to find out the mfr. and model of the amplifier and look it up and see if it passes MoCA frequencies. Seems to be the most likely suspect, I guess.
Thanks!
Here's what I did:
Thanks!
