Gs305
ronorbar
Does anyone have experience with the gs305 switch connected to the gt ax6000 router? Works well for extensive ports?
I'm running 2 GS108 and 1 GS516v2 switches for years with no issues at all. They've seen multiple router changes and never gave any problems. The GS105 is the 5-ports version of the 8-ports SOHO-oriented switch (GS108). Most unmanaged switches are almost the same inside, so you can do little wrong regardless of brand.
What is recommended from Netgear's unmanaged series?
Netgear GS108. $33.99 Ships from Amazon.com, Sold by Amazon.com
https://www.amazon.com/gp/product/B00MPVR50A/?tag=snbforums-20
Netgear GS105. $34.99.
https://www.amazon.com/dp/B0000BVYT3/?tag=snbforums-20
TP-LINK SG108 is on sale. $19.79.
https://www.amazon.com/dp/B00A121WN6/?tag=snbforums-20
TP-LINK SG105. $15.99.
https://www.amazon.com/dp/B00A128S24/?tag=snbforums-20
About TP-LINK Switches.
Pros: Cheap. Good enough.
Cons: Cheap power adapter with high pitch noise.
