2021/01/26 65.08 MBytes
ASUS GT-AC5300 Firmware version 3.0.0.4.386.41793
1. AiMesh 2.0
- System optimization: one click in AiMesh to optimize the topology
- System Ethernet backhaul mode, all nodes will only connect by ethernet, and all bands can release for wireless clients.
- System factory default and reboot.
- Client device reconnect, make the device offline and online again.
- Client device binding to specific AP.
- Guest WiFi on all Mesh nodes (all node need to upgrade to 3.0.0.4.386 firmware)
- Access nodes USB application.
Connection priority and Ethernet backhaul mode introduction
How to setup ASUS AiMesh or ZenWiFi Mesh Ethernet backhaul under different conditions
2. New Family interface in ASUS router App.
ASUS Router App for iOS must greater than iOS v1.0.0.5.75
Android version greater than v1.0.0.5.74
3. The unit of the WiFi time scheduler goes to 1 minute.
4. Support IPSec IKE v1 and IKE v2, and you can use the Windows 10 native VPN client program to connect to the router's IPSec VPN server. The Windows 10 new FAQ is in https://www.asus.com/support/FAQ/1033576
5. 2.4 and 5G settings on the network map could modify in the same tab.
6. Captcha for login can be disabled in the administration -> system.
7. Printer server port can be disabled on the USB app page.
8. Clients who connect to the guest network can be viewed in the network map -->view list --> interface
9. Fixed Let's Encrypt issue.
10. Added IPTV supports for a specific region.
Please unzip the firmware file first then check the MD5 code.
MD5: ee65d41542ebce9947a261ef4405d812
Released! Mesh 2
CC
1. AiMesh 2.0
ROG Rapture GT-AC5300 | Gaming Routers|ROG - Republic of Gamers|ROG USA
A powerful yet easy managing VR ready gaming Wi-Fi router. Best solution for PS4, Xbox and PC gaming. Supporting tri-band 802.11AC. Providing speed up to 5300 Mbps.
rog.asus.com
Released! Mesh 2
CC
