Hi All,
I'm struggling with how to enable remote access to Plex while using a VPN. Wondering if anyone has any experience with this.
I've got an Asus GT-AX11000 running the latest firmware (3.0.0.4.384_8011-gf86f4e8).
I've got my Plex server running on a Synology DS918+. Everything worked fine before using a VPN. I just had to add manual port forwarding on the router (i.e. manually specified Plex public port routed to internal port 32400) and that worked fine to ensure remote access to Plex.
I then signed up for Surfshark VPN and got it set up in the VPN Fusion tab on the router. Using OpenVPN, I've got a couple of servers set up (diff locations) and my NAS is going through one. It works as expected and is great but, obviously, when using the VPN, Plex is no longer reachable from outside my network.
To make Plex reachable, I understand that I have to edit the ovpn config file to ensure that Plex connections do not to go through the VPN.
I've looked at lots of forums. They generally seem to be getting at the same thing - the most comprehensive I could find is here: https://www.reddit.com/r/PleX/comments/3ymh65/a_guide_on_using_plex_with_openvpn/. I followed that to edit the .ovpn config file. I added three lines, as I got three different Plex IP addresses when I followed Step 2 in that guide; they looked like this:
Has anyone had any luck doing this? Is there some other way of achieving it?
This is not something I'm particularly familiar with so apologies if my language isn't perfect. Any help would be greatly appreciated! TIA
route [plexaddresses] 255.255.255.255 [mygateway].
I saw that some people had luck with a different subnet mask so I also tried a variation that looked like this: route [plexaddresses] 255.255.255.0 [mygateway].
I kept the previous port forwarding, as that should have done the job (or so I thought). However, no matter what I tried, it just won't work for me.Has anyone had any luck doing this? Is there some other way of achieving it?
