GT-AX11000, VPN and Plex
That's exactly right - the Synology DiskStation Manager (DSM) is the OS for Synology DiskStation and RackStation products, just like QTS is for QNAP products.
Thank you for all your advice - what a wealth of knowledge! Based on the above, I think what I've done (i.e. torrent client through the VM) is probably the best solution for how I use my system. Everything's working well. Really appreciate your help :)
Thanks and it's pleasure to try and help.
As an old friend of mine once said "the best choice is what's fit for purpose and simplest" (well, I changed it a bit but the gist is the same).
