gt-ax11000
DAVID LIVADITIS
hello can someone help me with pia vpn ?Everything was working on my gt-ax11000 decided to do a firmware upgrade to merlin 386.3
and now my vpn not working. so did a hard reset on router and still no luck
service state Connected (Local: 10.10.112.224 - Public: unknown)
Aug 1 12:36:01 rc_service: httpd 32707:notify_rc start_vpnclient1
Aug 1 12:36:01 ovpn-client1[7838]: DEPRECATED OPTION: --cipher set to 'aes-128-cbc' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM:AES-256-CBC:AES-128-CBC).
Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'aes-128-cbc' to --data-ciphers or change --cipher 'aes-128-cbc' to --data-ciphers-fallback
'aes-128-cbc' to silence this warning.
Aug 1 12:36:01 ovpn-client1[7838]: OpenVPN 2.5.3 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jul 23 2021
Aug 1 12:36:01 ovpn-client1[7838]: library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.08
Aug 1 12:36:01 ovpn-client1[7839]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Aug 1 12:36:01 ovpn-client1[7839]: CRL: loaded 1 CRLs from file crl.pem
Aug 1 12:36:01 ovpn-client1[7839]: TCP/UDP: Preserving recently used remote address: [AF_INET]154.57.3.101:1198
Aug 1 12:36:01 ovpn-client1[7839]: UDP link local: (not bound)
Aug 1 12:36:01 ovpn-client1[7839]: UDP link remote: [AF_INET]154.57.3.101:1198
Aug 1 12:36:02 ovpn-client1[7839]: [athens402] Peer Connection Initiated with [AF_INET]154.57.3.101:1198
Aug 1 12:36:02 ovpn-client1[7839]: TUN/TAP device tun11 opened
Aug 1 12:36:02 ovpn-client1[7839]: /usr/sbin/ip link set dev tun11 up mtu 1500
Aug 1 12:36:02 ovpn-client1[7839]: /usr/sbin/ip addr add dev tun11 10.10.112.224/24
Aug 1 12:36:02 ovpn-client1[7839]: ovpn-up 1 client tun11 1500 1553 10.10.112.224 255.255.255.0 init
I have the same issue. Can't get a public IP.
  • syslog (1).txt
There must be like a dozen of similar posts by now. Please do some reading first, kinda getting tired here of repeating the same one-line answer every single time: Configure "Redirect Internet Traffic" properly.
