GT-AX600 Smart Connect, MIMO, WiFi Agile Multiband etc.
I wouldn't be reporting a bug. I'd be doing an exchange/refund right now.
Doesn't the software control the hardware? The hardware isn't responding to the software commands?
If you see the same behavior in stock Asuswrt - report it to Asus in Administration, Feedback form.
If it happens in Asuswrt-Merlin only - report it in the corresponding Asuswrt-Merlin thread here on SNB Forums.
We know the software works (from many others' experiences here).
Your particular hardware isn't working as expected.
Again; I would be doing an exchange/refund right now.
Unless someone can corroborate this behavior with their GT-AX6000 too (of course).
Ok I did a hard reset and flashed ASUSWRT 3.0.0.6_102_21514. Disabled radio on 2.4GHz and ssid didn't show in clients. Did a hard reset, Flashed Merlin 388.2_2 and disabled radio on 2.4GHz and ssid is not showing in clients. Note to self, always do a hard reset before flashing.
Thanks Tech9 and L&LD!
Instruction was to Hard Reset the firmware before you configure it... did you do that?
OE
OE
No I didn't catch that. Only did hard reset before flashing. I will have to do all over again-PITA.
