GT-AX6000 Alpha Firmware
checking for sys/socket.h... yes
checking for arpa/inet.h... yes
checking for features.h... yes
checking for sys/param.h... yes
checking for unistd.h... (cached) yes
checking for dirent.h... yes
checking for fnmatch.h... yes
checking for stdio_ext.h... yes
checking for sys/stat.h... (cached) yes
checking for netdb.h... yes
checking for netinet/in.h... yes
checking for getopt.h... yes
checking for sys/cdefs.h... yes
checking for termios.h... yes
checking for sys/time.h... yes
checking for threads.h... yes
checking for iconv.h... yes
checking for limits.h... yes
checking for inttypes.h... (cached) yes
checking for sys/types.h... (cached) yes
checking for stdint.h... (cached) yes
checking for crtdefs.h... no
checking for wctype.h... yes
checking for langinfo.h... yes
checking for xlocale.h... no
checking for sys/mman.h... yes
checking for malloc.h... yes
checking for sys/select.h... yes
checking for spawn.h... yes
checking for strings.h... (cached) yes
checking for sys/file.h... yes
checking for sys/ioctl.h... yes
checking for sys/random.h... yes
checking for sys/uio.h... yes
checking for sys/wait.h... yes
checking for utime.h... yes
checking for stdlib.h... (cached) yes
checking whether it is safe to define __EXTENSIONS__... yes
checking whether _XOPEN_SOURCE should be defined... no
checking for arm-buildroot-linux-gnueabi-gcc... (cached) /opt/toolchains/crosstools-arm-gcc-9.2-linux-4.19-glibc-2.30-binutils-2.32/usr/bin/arm-buildroot-linux-gnueabi-gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether /opt/toolchains/crosstools-arm-gcc-9.2-linux-4.19-glibc-2.30-binutils-2.32/usr/bin/arm-buildroot-linux-gnueabi-gcc accepts -g... (cached) yes
checking for /opt/toolchains/crosstools-arm-gcc-9.2-linux-4.19-glibc-2.30-binutils-2.32/usr/bin/arm-buildroot-linux-gnueabi-gcc option to accept ISO C89... (cached) none needed
checking whether /opt/toolchains/crosstools-arm-gcc-9.2-linux-4.19-glibc-2.30-binutils-2.32/usr/bin/arm-buildroot-linux-gnueabi-gcc understands -c and -o together... (cached) yes
checking whether the compiler is clang... (cached) no
checking for compiler option needed when checking for declarations... (cached) none
checking dependency style of /opt/toolchains/crosstools-arm-gcc-9.2-linux-4.19-glibc-2.30-binutils-2.32/usr/bin/arm-buildroot-linux-gnueabi-gcc... (cached) none
checking build system type... x86_64-pc-linux-gnu
checking host system type... arm-buildroot-linux-gnueabi
checking whether make supports nested variables... (cached) yes
checking for library containing dlopen... -ldl
checking for Minix Amsterdam compiler... no
checking for arm-buildroot-linux-gnueabi-ar... /opt/toolchains/crosstools-arm-gcc-9.2-linux-4.19-glibc-2.30-binutils-2.32/usr/bin/arm-buildroot-linux-gnueabi-ar
checking for _LARGEFILE_SOURCE value needed for large files... no
./configure: line 8908: syntax error near unexpected token `;;'
./configure: line 8908: `    gl_YEAR2038_BODY() ;; #('
make[4]: *** [Makefile:7220: wget/Makefile] Error 2
make[4]: Leaving directory '/home/ubuntu/amng-build/release/src/router'
make[3]: *** [Makefile:33: router_all] Error 2
make[3]: Leaving directory '/home/ubuntu/amng-build/release/src-rt-5.04axhnd.675x/userspace'
make[2]: *** [build/Makefile:358: userspace] Error 2
make[2]: Leaving directory '/home/ubuntu/amng-build/release/src-rt-5.04axhnd.675x'
make[1]: *** [Makefile:5551: bin] Error 2
make[1]: Leaving directory '/home/ubuntu/amng-build/release/src-rt-5.04axhnd.675x'
make: *** [Makefile:5747: gt-ax6000] Error 2
ubuntu@merlin:~/amng-build/release/src-rt-5.04axhnd.675x$
Your LD_LIBRARY_PATH is probably not including the new toolchain location.
 CC      net/netfilter/xt_dscp.o
  CC [M]  net/wireless/of.o
net/netfilter/xt_conntrack.c: In function ‘conntrack_mt’:
net/netfilter/xt_conntrack.c:235:41: warning: passing argument 1 of ‘nf_ct_expires’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
  235 |   unsigned long expires = nf_ct_expires(ct) / HZ;
In file included from net/netfilter/xt_conntrack.c:19:
./include/net/netfilter/nf_conntrack.h:291:59: note: expected ‘struct nf_conn *’ but argument is of type ‘const struct nf_conn *’
  291 | static inline unsigned long nf_ct_expires(struct nf_conn *ct)
  CC      net/netfilter/xt_helper.o
  CC      net/netfilter/xt_iprange.o
  CC      net/netfilter/xt_limit.o
  CC [M]  net/wireless/shipped-certs.o
  CC      net/netfilter/xt_mac.o
  LD [M]  net/wireless/cfg80211.o
  CC      net/netfilter/xt_multiport.o
  CC      net/netfilter/xt_policy.o
  CC      net/netfilter/xt_recent.o
  CC      net/netfilter/xt_state.o
  CC      net/netfilter/xt_statistic.o
  CC      net/netfilter/xt_string.o
  CC      net/netfilter/xt_tcpmss.o
  CC      net/netfilter/xt_time.o
  CC      net/netfilter/xt_u32.o
  CC      net/netfilter/xt_webstr.o
  CC [M]  net/netfilter/nf_conntrack_ftp.o
  CC [M]  net/netfilter/nf_conntrack_h323_main.o
  CC [M]  net/netfilter/nf_conntrack_h323_asn1.o
  CC [M]  net/netfilter/nf_conntrack_sip.o
  CC [M]  net/netfilter/nf_conntrack_tftp.o
  CC [M]  net/netfilter/nf_nat_ftp.o
  CC [M]  net/netfilter/nf_nat_sip.o
  CC [M]  net/netfilter/nf_nat_tftp.o
  CC [M]  net/netfilter/nf_tables_core.o
  CC [M]  net/netfilter/nf_tables_api.o
  CC [M]  net/netfilter/nft_chain_filter.o
  CC [M]  net/netfilter/nf_tables_trace.o
  CC [M]  net/netfilter/nft_immediate.o
  CC [M]  net/netfilter/nft_cmp.o
  CC [M]  net/netfilter/nft_range.o
  CC [M]  net/netfilter/nft_bitwise.o
  CC [M]  net/netfilter/nft_byteorder.o
  CC [M]  net/netfilter/nft_payload.o
  CC [M]  net/netfilter/nft_lookup.o
  CC [M]  net/netfilter/nft_dynset.o
  CC [M]  net/netfilter/nft_meta.o
  CC [M]  net/netfilter/nft_rt.o
  CC [M]  net/netfilter/nft_exthdr.o
  CC [M]  net/netfilter/xt_set.o
  CC [M]  net/netfilter/xt_HL.o
  CC [M]  net/netfilter/xt_TPROXY.o
  CC [M]  net/netfilter/xt_TEE.o
  CC [M]  net/netfilter/xt_comment.o
  CC [M]  net/netfilter/xt_hashlimit.o
  CC [M]  net/netfilter/xt_hl.o
  CC [M]  net/netfilter/xt_length.o
  CC [M]  net/netfilter/xt_quota.o
  CC [M]  net/netfilter/xt_sctp.o
  CC [M]  net/netfilter/xt_socket.o
  CC [M]  net/netfilter/xt_condition.o
  CC [M]  net/netfilter/xt_geoip.o
  AR      net/netfilter/built-in.a
  LD [M]  net/netfilter/nf_conntrack_h323.o
  LD [M]  net/netfilter/nf_tables.o
  AR      net/built-in.a
make[4]: Leaving directory '/home/ubuntu/amng-build/release/src-rt-5.04axhnd.675x/kernel/linux-4.19'
make[3]: *** [Bcmkernel.mk:83: default] Error 2
make[3]: Leaving directory '/home/ubuntu/amng-build/release/src-rt-5.04axhnd.675x/build'
make[2]: *** [build/Makefile:509: kernelbuild] Error 2
Crosscompiling something as complex as Asuswrt is not easy. You will have to do your own troubleshooting there, sorry.
