deviceunifier
I've upgraded to an Asus GT AX6000, running stock firmware 3.0.0.6.102_34810. I have set up an IoT network in the Guest Network Pro feature to segregate my IoT devices. My Home Assistant is a docker container on my home server which is on my main network. It is having trouble integrating some smart bulbs and plugs. I can find them by manually adding the their ip from the IoT VLAN but it prompts me to authenticate. When I try this it fails with "Connection error: try_connect_all failed".
After some googling I found some posts that say the native asus router firmware lacks inter-vlan communication. When I try to ping the devices from my HA machine I get 100% packet loss, and when I try to ping my HA machine from the IoT network I also get 100% packet loss which seems to confirm this. However, a few posts say you can get around this by using ssh to access the router and add some iptables rules to allow this traffic.
I have accessed the router with ssh and used
If I use
If I use
After referencing the iptables manual and If I am understanding all this correctly it is saying the 2 rules appear to be stopping the traffic between the IoT network and the default gateway and between any network interfaces, but the main network allows all connections everywhere, thus it appears changing some rules should allow me to achieve communications between the VLANs.
I think the better option to take here is to move HA to it's own dedicated machine and have it on the IoT network. Ideally I would like keep these rules, as they act like a deny all filter, and just create new ones to selectivity allow inbound and outbound traffic of the devices on my main network that need to communicate with HA on the IoT network and vice versa. This way HA should work with everything and all the IoT devices are restricted.
However, I'm not familiar with iptables, I don't know how to achieve this or if it is even possible?
iptables -S
to see what rules have been added and noticed these:-A SDN_FI -d 192.168.50.1/32 -i br52 -j DROP
-A SDN_IA -i br+ -o br+ -j DROP
If I use
iptables -L -v | grep br52
to list the rules of the IoT network it returns with:94 5944 ACCEPT all -- br52 eth0 anywhere anywhere
76 6539 ACCEPT udp -- br52 any anywhere anywhere multiport dports domain,bootps,bootpc
0 0 DROP all -- br52 any anywhere network.lan
13 3776 ACCEPT all -- br52 any anywhere anywhere state NEW
If I use
iptables -L -v | grep br0
to list the rules of the main network it returns with:2336 963K PTCSRVWAN all -- !br0 any anywhere anywhere
1355 114K PTCSRVLAN all -- br0 any anywhere anywhere
1355 114K ACCEPT all -- br0 any anywhere anywhere state NEW
0 0 ACCEPT all -- br0 br0 anywhere anywhere
0 0 ACCEPT all -- br0 any anywhere anywhere
371 32414 ACCEPT all -- br0 eth0 anywhere anywhere
